Question about HP PSC 1610 All-In-One InkJet Printer
Error 0x805d0075 1615:fm_keywords is flashing in the display
The printer has the error 0x805d0075 1615:fm_keywords flashing in the display. I have unpluged both data and power cables and I still get this error msg.
It will not reset.
babb
  • 104 Answers
SOURCE: Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
Posted on May 15, 2007
adonscott
  • 106 Answers
SOURCE: error message
hi,
the error message you encounter is new to me. however, you can try to partialy reset your printer.
1. while the unit is turn ON, unplug the power cord from the back of the printer
2. press and hold the # and 3 buttons together and dont release.
3. while holding the two buttons, plug-in back the power cord from the back of the printer.
4. wait for a couple of seconds, it will give you a message on the printer screen "PARTIAL NVM RESET".. when you see that message, you may release the two buttons.
5. in some cases, after you plug-in the power cord button frmo the back of the printer, the printer will become ONLINE.. and after 30 seconds it will automatically turn off. when that happens, just release the two buttons and press the power ON button to turn it ON.
6. after turning it ON, it will give you message "PARTIAL NVM reset".
note: after performing the steps, your printer will make some noise and it will eventually stops. then try to check if you still have that error message.
- adonscott -
HP TECH
Posted on Jul 02, 2008
  • 3600 Answers
SOURCE: Power reset message
unplug it from the computer and unplug it from the wall socket and hold the power button down for 60 seconds then replug it back in to the computer and plug the power back on then turn it on.
Posted on Nov 20, 2009
SOURCE: Printer is showing "error: 0xf0af0001 Reset
last month i had same problem and i contacted customer care and i got this solution. And this works.
Step 1:
Perform a partial reset.
A partial reset returns the user settings to the factory defaults. The language and country/region settings may also be deleted.
Please perform the partial reset using the following steps:
a. Unplug the power cord from the all-in-one.
b. Press and hold the "#" and 3 button on the front panel keypad.
c. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize.
If the issue persists, follow Step 2.
Step 2:
Perform a semi-full reset.
b. Press and hold the "#" and 6 button on the front panel keypad.
Posted on Aug 02, 2010
  • 684 Answers
SOURCE: Lights flash and message appears
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on Sep 18, 2011
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
My printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
my printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
Jan 18, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Printer stops on bootup. displays printer error. To display turn off then on
if you press the ? button, does it show a secondary error code?
You might have corrupted the firmware if you tried to flash it.
also possible formatter/firmware failure or corruption.
Jan 06, 2010 | HP LaserJet 4300 Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
Blk 0 chksum error
fault "blk 0 chksum error" is attributable to a corrupt firmware. Fortunately the firmware can be reloaded and restore the printer in operating condition. You can download a firmware from the tallygenicom.com site under support and drivers then download it in your PC. Normally you need to put the printer is flash download mode also instruction can be seen from the site. If you cannot do this I can assist you with this.
Jul 27, 2007 | Tally Line Matrix T6100 Printer
HP PSC 1610 All-In-One InkJet Printer Logo
234 people viewed this question
Seeker5211
Seeker5211
