Will not power up
Presario f500, no power, power supply is good. was getting "battery not charging" before it stopped working.
  • 37 Answers
Most likely, your power adapter failed to charge the battery of your computer or the battery of your computer is starting to fail.
Posted on Jun 02, 2009
Battery/charger
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
Feb 17, 2014 | HP Compaq Presario F500 F700 and G6000...
Light stays orange
This could be a bad battery not taking a charge. Pull the power supply and see how long it stays on. Batterys only last about 3 years then need replacement.
Terry
Dec 20, 2012 | HP Compaq Presario F500 F700 and G6000...
I have a Compaq Presario F500 When I press the power button all the lights light up for a few seconds then it shuts back off
remove the battery then try to plug the charger directly on your laptop without a battery.. to test if the battery is working properly. if not.. maybe your main board have a problem. just like athe compaq presario of my friend. also mainboard problem.
Jul 10, 2011 | HP Compaq Presario F500 F700 and G6000...
My compaq presario f500 won't start on battery and is turned off when the main supply is cut suddenly. the battery icon says 97% available (plugged in, not charging). ?????? please help.. the laptop isn't...
I can tell you, screen issues and wireless issues are one of the problems that goes with a laptop that is GOING TO FAIL. In your case, the F700 is the more expensive F500 which was confirmed by HP to be a failure/defective. But you have the f500 - I actually had this problem, and what I did was I cleaned off the battery contacts with rubbing alcohol on a q-tip and it worked again, but for you, this might be a sign of hte laptop failing.
First the problem manifests as a loss of the wireless connection. Soon, intermittent failures and random reboots and a HOT laptop will turn into a black screen and an inoperable laptop > ie a door stop.
Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
This issue has actually landed me in small claims court where I am suing for hte full cost of this laptop because not only is hte laptop defective, nVIDIA admitted it, and HP covered it up.
Join us at hplies.com and we will give you the know how to get this issue fixed/your $ back. We even have links to all of the information!
Send me a PM if you want more assistance.
Dec 06, 2009 | HP Compaq nc6000 Notebook
Cant turn On my Compact presario f700
Assuming you have checked the the power strip or outlet by testing it with another electrical appliance to see if it is in operation, you can test
the power supply to the unit with a tester or oscilloscope. If it still does not work then check the cable that plugs directly into the unit and replace it if necessary. You can also open the unit to check if the cable is attached properly to the motherboard.
Aug 26, 2009 | HP Compaq Presario F500 F700 and G6000...
Presario wont turn on. its an f500, i turn it on and it immediately turns off, screen wont come on...im assuming i need a new battery? want advice before i purchase the battery!!
Remove the battery, plug the wall adapter in and try to boot. If it works, the battery is the problem. If not; is the green indicator on the power brick on? If not, replace the power supply brick. If all the above is ok, the problem is internal and I would be guessing without testing.
Jul 25, 2009 | HP Compaq Presario F500 F700 and G6000...
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
