Agitator not working on washing machine
Top of agitator does'nt turn
    President:
  • 1,136 Answers
Hi, You will need to replace the do kit inside the agitator. Remove the cap to the agitator and you will see a 7/16" bolt holding the two pieces together. The part # 285770
You can order these parts on my web site
www.whirlpoolpartssurplus.com
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 02, 2009
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop ....in its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
michael, try running the wash cycle under different levels eg. normal, delicate etc without a load and see if it agitates.If not, the mechanism has diengaged.
Mar 03, 2014 | Washing Machines
How remove agitator cup to replace dogears on a kenmore elite washing machine
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Feb 12, 2011 | Kenmore Washing Machines
I have a Kenmore 111 triple action washing machine. The top part of the agitator is not working but the bottom is. I am only able to do smaller loads. I have 4 active boys so this is not going to work. ...
Dec 08, 2010 | Washing Machines
Top part of agitator is loose not washing clothes correctly
Aug 30, 2010 | Washing Machines
My washing machine only turns one way now. it
Mar 15, 2010 | Washing Machines
Agitator only turns clockwise (Whirlpool top load)
You will need to replace the dogs under the agitator, they are pretty easy. Just pop the cap, take out the center bolt, remove it the dogs are 4 teeth looking items.
Mar 12, 2009 | Whirlpool LSB6200KQ Top Load Washer
Top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Feb 25, 2009 | Washing Machines
My washing machine spins but will not agitate
Turn the agitator (auger) by hand. It should work like a ratchet (turns one way, locks the other way). If it spins both ways, you need to replace the agitator dogs (funny name, I didn't make it up).
This can be done by removing the top cover off the agitator and removing the bolt that holds the agitator to the drive shaft. Then remove the top section, flip it over and replace the dogs (small white plastic pieces). Reassemble in reverse manner.
If the agitator dogs are ok, you may need a gearcase (transmission).
Feb 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
