Question about KitchenAid KGYS850LT Gas Dryer
Accessing the igniter on a Kitchenaid Dryer
I have a Kitchenaid Superba Dryer (KGYS850JQ1) and want to test the igniter assembly. Where is this located? (I have already opened the back and checked the thermal fuse--resistance is 0). Most repair sites seem to indicate that access is via the front under the door, but there is no discernible way to open that. thnks.
    President:
  • 1,136 Answers
Normal 0 Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the ignitor attached to the burner. There is a harness you can unplug to test it. If the dryer is not heating at all, before you remove the front panel, you can remove the cap on the front lower panel and start the dryer. Look inside the holw and see if the ignitor glows at all.
If it glows and then shut down before the flame lights, you will need to change the coils on top the gas valve, not the ignitor.
If the ignitor does not glow at all, you will want to test the thermo fuse before the ignitor.
Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. I know this is a lot of info but these are most common problems.
If I can assist you further, please let me know.
Vic
Posted on Jun 02, 2009
Gas dryer pilot light
Hello Lara. Your dryer does not have a pilot light. It uses a hot surface ignitor to ignite the gas. Unplug the dryer and cover it with a plastic sheet before fogging.
Jul 08, 2016 | KitchenAid Dryers
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
Kitchenaid Superba whisper quiet gas dryer Model # ykgys777eq1 will not heat could be igniter, glow rod or coil help?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 31, 2011 | Dryers
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
My mother has a Kitchenaid Superba Dryer, gas, everything seems to work, but the unit won't heat.
WELL ITS 1 OF A COUPLE OF THINGS NO HEAT KITCHEN AID USES A THERMAL FUSE IN THE BACK OF THE DRYER CHECK THAT FIRST USE A MULTI METER FOR THAT ALWAYS UNPLUG ANY APPLIANCE WHEN DOING ANY WORK ON THEM IF YOU HAVE A GLOW DOWN ON BOTTOM IT COULD BE THE FLAME SENSOR IS BAD OR GAS VALVE COILS ARE NOT LETTING THE GAS OUT OR YOUR GAS IS OFF AT MAIN FROM HOUSE GOOD LUCK GEORGE
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Dryer also stopped working (3 years old)
Yes it is, you can bypass it for testing purposes only, also clean out your vent too the outside it is probably clogged that is what usually blows them out.
Jul 24, 2008 | Dryers
KitchenAid KGYS850LT Gas Dryer Logo
1,016 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
