Question about Panasonic NV-GS17 Mini DV Digital Camcorder
LCD screen goes blank on my Panasonic NV-GS17 camcorder
The screen works fine when it is opened a little way but when the screen reaches about 45 degrees the picture disappears. It appears to be the flexible link between the camera body and the screen. Can you get a replacement connection and is it difficult to replace it as a DIY job.Although the camera is 3 years old it has not had a lot of use from new! Can't offer a solution, but I have the exact same problem.
  • 30 Answers
You need to replace your camara's flex cable (LCD HINGES-technical name).
Posted on Jun 07, 2009
When I open out the screen of my Panasonic NG- GS17 Mini DV digital camcorder, the picture gets all fuzzed and turns to blank white. It's only if I open the screen out more than roughly 2cm, when the...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 01, 2011 | Panasonic NV-GS17 Mini DV Digital...
When opening the lcd screen on my nv-gs17 the screen is blank, although the camera works just fine
Has the camera been switched to internal viewfinder mode? Many cameras have this feature (mine does) for people who like the old fashioned method of looking through the little viewfinder rather than using the screen on the back - saves battery too. Look for a button with a symbol that looks like a box with a vertical line on the left and right of it. press it and the screen should come back.
Hope this helps.
Apr 27, 2011 | Panasonic Cameras
Hi, I have a Panasonic NV-GS17EB.It is working perfectly fine and a nice camera. But recently the LCD view finder is giving some problem. It goes blank when I open the LCD view finder fully. But it...
the ribbon cable that carries the signal to the screen sounds like it has become damaged
thatcan cause the problem
when it is all the way open it stretches the cable resulting in a gap to form, so when only open part of the way there is still a signal. see if there is anything in the hinge that might be causing the stretching of the cable, as that is almost surely the problem..
Dec 16, 2010 | Panasonic NV-GS17 Mini DV Digital...
I have panasonic PV-GS32 camcorder. The lcd was working fine for 2-3 years but suddenly stopped working. If i flip open the LCD screen then the viewpoint also goes blank. Is there some setting that needs...
It does look as if your LCD screen is dead, they are not cheap to replace, but you could pop it in to your local Camera shop, they will mostly be glad to help you.
Jun 16, 2010 | Panasonic NV-GS17 Mini DV Digital...
Out of synch sound & video Panasonic NV-GS17
Hi, did you get the issue resolved? i have te same problem an it is becoming a nignmare!
Aug 09, 2009 | Panasonic NV-GS27 Mini DV Digital...
Black screen
Try cleaning it with a DV tape cleaner and see if that makes a difference.
Jul 29, 2008 | Panasonic NV-GS17 Mini DV Digital...
Blank Screen When Recording
hi, if you have an on screen display in camera mode you should check into the lens to see if your shutter or iris is opening.
Jul 23, 2008 | Panasonic NV-GS17 Mini DV Digital...
Panasonic ns.gs17
if you can open your camera...find the small fuse..in panasonic camera normally its color yellow indicate 3.15 amp fuse value near the battery back socket
Aug 09, 2007 | Panasonic NV-GS17 Mini DV Digital...
Panasonic NV-GS40
the possible fault may be bad image senser CCD. you require a professionl to change the CCD.
Jun 22, 2006 | Panasonic NV-GS17 Mini DV Digital...
Panasonic NV-GS17 Mini DV Digital Camcorder Logo
1,080 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
