Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 constant paper jams
Paper folds up like an accordian in the back of the machine. Pull the paper out but it jams after a copy or two.
Most likely the fuser is worn out, and needs replacement
Posted on Jun 06, 2009
Paper jams in back of machine?
you have an obstruction either a piece of paper between the rolllers or the secondary feed rollers are not turning.... open the machine and follow the feed path ...take a piece of paper and manually feed the paper with the machine in the off position look at the feed rollers then the secondary rollers( usually two small rods with rubber sleeves kissing each other ...if you can look at the sides on the machine( inside the cover) see if the gears ( usually white ) can turn or mesh correctly... if you do not see any obstruction then these rollers are not turning when they are supposed to when you press the print button. 90 percent of these problems are paper jams if no jam something is not activating the feed rollers
Sep 05, 2014 | Brother IntelliFax-2820 Laser Fax
I have a brother intellifax 2820 the error message is "the back door is open" the back door is closed , however when i open the back door paper is stuck, whixh i have to remove , how do i correct...
i'm assuming its making an "accordian" type jam. if so, your exit rollers need to be cleaned. you can use water on a rag or windex. the problem is the average user being able to access rollers. looking from front of machine, look closely where your faxes come out, you will see 4 rubber rollers riding on top of 4 wide, plastic rollers. the rubber ones are the exit rollers needing cleaned.
good luck
razors
Sep 21, 2011 | Brother IntelliFax-2820 Laser Fax
When receiving a FAX or printing a receipt, it repeatedly jams. The paper is found inside the back cover baked into a folded fan shape.
This folded pattern indicates that the jam is being caused by a physical obstruction in the paper path section. I would suggest manually feeding a thick piece of cardstock paper and seeing if you can find the location of the jam, as it is most likely a piece of trapped paper or plastic tab that has come out of its original position.
-David.
Nov 05, 2010 | Brother IntelliFax-2820 Laser Fax
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
My printer folds the paper in the back accordian
check the drum unit and toner unit, also check on all rolls inside the printer.
if still not working you can send it to me to fix it for you.
Jul 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper keeps getting jammed at the back
What happened is that the fuser has quit working properly. You would need to have the fuser replaced.
Mar 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
688 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
