Question about Minolta EP1083 CS/PRO Copier
The copies are coming out smeared and with lines. I wiped the (drum?) off?
Our copier(Minolta CS Pro 1080) began to print a dark wide strip on our copies. I think I removed the (drum?) wiped it down, and now it prints smeared!!! What can I do? do I need a new drum? The toner cartridge is brand new!
  • Minolta Expert
  • 1,326 Answers
What did you wipe the drum off with???? That is why you have this problem. You may want to try recleaning the opc with a dry soft rag, also you may want to clean the drum blade... If that dose not solve your problem, you may need to replace the opc & blade... Have you tried to stop the copy before it gets to the fuser unit.. If so, are the marks there???
Posted on Jun 03, 2009
Copier is printing dark lines throughout the pages
Mite need to have the drum replace and check the charge corona housing above the drum when you pull the drum unit out.. Also check the fuser unit the hot part.
Jan 17, 2014 | Minolta EP1083 CS/PRO Copier
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
I have a minolta ep2030 and when i hit copy all i get is black page.
- clean the scanner optics
- if this don't work check and replace drum cleaning blade
Jul 26, 2012 | Minolta EP1030/1030F CS/PRO Copier
When photocopying the copies come out with dark lines across them
Clean or change the OPC drum cleaning blade,the drum.Clean the charge corona wire and grid,clean the optics,mirrors,transfer and separator corona wires.
Sep 13, 2011 | Minolta EP1030/1030F CS/PRO Copier
There is a dark vertical line of toner on prints
Common problem. Most likely caused by a bad drum cleaning blade. This is especially true if you run say 10 copies and the last copy out of the machine is worse than the first copy out. Drum cleaning blades are cheap at less than $30.00.
Good Luck and Thank You using Fixya.
Sep 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
1/3 OF RIGHT SIDE OF PAGE DARK OR LINED TOP TO BOTTOM
Drum Cleaning Blade failure. Open up the top half of the machine as if you were removing a paper jam. Now look under the top half and about in the center from left to right. You should see a burgundy colored cylinder running from the front of the machine to the back. If you can see the toner streaks on the surface....expecially on the 1/3rd like on the copy then this will be proof that the drum cleaning blade is the cause. Simple repair for a tech that knows copier basics. A good estimated cost would be about $25.00 for the blade and whatever the going rate is for a service call in your area.
Jan 28, 2010 | Minolta EP1083 CS/PRO Copier
Minolta Copier EP1083, copies are coming out mostly black
What you mostly need to do is to clean the optics under the copyboard glass the mirrors are mostly dusty... I would use a soft dry cloth to wipe the mirrors off. There is a mirror under the "Black Box" I would also, use a lightly damp rag with rubbing alcoh. to wipe OFF the scanning lamp & reflector. Cleaning the optics should get read of the dark back ground, but the drums are only good for 80k... You may need a new OPC drum & blade. Good Luck
Mar 02, 2009 | Minolta EP1083 CS/PRO Copier
Minolta 1030
Depends if the lines go across the page as if the paper comes out or if they go down the page. If across then poss drum, transfer, or fuser unit, If down the page could be a short on the charge then poss only drum unit.
Thanks Jason
Aug 16, 2008 | Minolta EP1030/1030F CS/PRO Copier
241 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
