Back to:
Tags:
Microsoft Xbox 360 Console
Xbox 360 screen wont show up (by 44 users)
posted by fart magnet on Oct 24, 2007
i was playing and one day i turned it on and the sound worked perfectly but the screen dident come up i bought new cables still nothing so what do i do.........
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
43 Other Users Have The Same Problem
Comment by Guest, posted on Sep 24, 2008
same stuff.i forget what the thing is called but its a burnt chip.its from playing too much, usually happens when you have one of those crappy coolers on the back.and by the way those coolers are only bad for your xbox.it blows more air back in to your xbox than it does out.just thought i'd try to save you guys some money
Same Problem Here. Dumb **** Microsoft...
Comment by Guest, posted on Sep 07, 2008
I can hear the game playing but i cannot see anything on the screen
Comment by Guest, posted on Sep 06, 2008
that it work but doesn't show screen then three red light show!!
Comment by adidass11, posted on Aug 27, 2008
I just got an xbox 360 and when i plug it in then turn it on i can hear it working perfectly but the screen just remains black.
Best Solution
posted on Jun 28, 2008
FixYa! (100)
chrjd12
Rank:Apprentice Apprentice
Rating: 95%, 18 votes
If the console is not under warranty (hence you removed the seal) there is a simple fix for this - Do not do the towel trick - harms the cpu and the gpu also only works for a little while.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on xbox 360 screen wont show up:
I don't want to Accept this solution
Solution #2
posted on Feb 14, 2008
Helpful (85)
Folro
Rank:Wiz Wiz
Rating: 86%, 41 votes
This is a difficult solution to recommend but the towel trick does work, let it over heat the 360 for about 20 min, then let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Thank You!
Solution #3
posted on Jan 13, 2008
Thanks for Trying (70)
warrion03
Rating: 70%, 2 votes
  1. ok try to let it cool for 30-50 min then turn it on if stiil dosent then wipe all prongs and then plug them back in the tv now try to turn it on still no work try new cables still no work try new tv. but check if the switch is set to hd or tv{if u have hd switch to hd if tv turn to tv}.
  2. try to get a new consle if to much $ try sending to the manufraturer. that all that i can offer
Thank You!
Solution #4
posted on Oct 25, 2007
X 4PLANK X
Rating: 67%, 10 votes
right yh same here... i tryed putting it on another T.V it allmost worked for me but im guessing I need a new lead, but for you it may work, give it a try. if that doesn't work i really dont know, i tryed goin to the shops about it but they said the problem was new to them.
Thank You!
Solution #5
posted on Jun 23, 2008
Guest
Rating: 0%, 0 votes
BUY A PS3
Thank You!
Solution #6
posted on Jan 02, 2008
Inappropriate (40)
Guest
Rating: 0%, 0 votes
Send it in to xbox they'll fix it. Takes forever but they'll do it. If you can make it that long.
Thank You!
Solution #7
posted on Aug 30, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
well i dont know what to do with mine ive tryed evry thing iv put it on a new t.v and tryed new cables and all sorts and i wont work. i have no idea what the towel trick is but can someone tell me.
Thank You!
Solution #8
posted on Aug 21, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
you have to change the display settings, if your swiching from one tv to another and only the first suports 720 dpi then it wont display. thats what i heard anyway
Thank You!
Solution #9
posted on Aug 10, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
i dont get the answer is says heres a solution then it says do not do the towl trick wtf dose he mean im confused :(
Thank You!
Solution #10
posted on Jul 26, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
idk
Thank You!
Solution #11
posted on Jul 25, 2008
Not Rated (0)
yurpy
Rating: 0%, 0 votes
well my xbox cant be over head cuz when i went into my basement it was off in the first place...i turned on my xbox and switched tv to the right video but when i switched it the sound worked find but there were lines on white dots floating on my screen...what was that about??
Thank You!
Solution #12
posted on Feb 09, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
sollution #4 just wokred for me, thanks!
Thank You!
Solution #13
posted on Feb 07, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
i hav tried cleaning all the plugs still no joy, i even borrowed my m8's new leads that didnt work either so i suggest sending back to manafacturer
Thank You!
Solution #14
Not Rated (0)
Deadly Dr D
Rating: 0%, 0 votes
I am waiting for my box from Microsoft to send in my console for repair on this issue. I figured I would try "the towel trick" while waiting and it worked. The First time it resurrected my console for about 5-6 hours. The second time It has worked for 2 days without the funky color problem.
Thank You!
Can you Help with these Video Game Consoles problems?
when i sign onto my xbox live account, the whole system...
The disc won't eject & the green power light keeps...
when i turn my xbox 360 on it gets to the dashboard and it...
When I put game in my console disc is not being read or it...
Power light in the middle keeps flashing. Won't eject disc...
43 Other Users Have The Same Problem - Continued
Comment by mrpogo25, posted on Aug 27, 2008
screen wont show up, nor the sound
Comment by Guest, posted on Aug 13, 2008
when i turn the 360 on all i can see is puple dot an i can hear the sound
Comment by chrs_cckrll, posted on Aug 10, 2008
my xbox 360 will turn on but on the tv screen i see nothing
Comment by brooksmil_12, posted on Aug 09, 2008
the sound works fine but i cant see anything.....ive tried new cables and tvs but nothing works
Comment by mzoheeb99, posted on Aug 07, 2008
start up my xbox 360 and i can hear only sound i switch it off again and back on still same thing again i switch it of and on and a get 3 flashing lights!!! red ring of death
Comment by miguel sanch, posted on Aug 05, 2008
i turn on my xbox 360 and the regular sounds are there but the normal start up picture or any picture for that matter is there, only the sound.
Comment by edge426, posted on Jul 26, 2008
Got a new 50 inch plasma, moved xbox to this and worked fine for some time. The colors got all distorted...like way back when your nintendo was set to channel 4 but you had tv tuned to channel 3...then moved it back to regular tv. Days later, no video at all...just audio. Still covered under Best Buy so sent in AV cable. Got new one and still and issue. Guess the whole Xbox is going to have to go back. Odd though, browsing xbox forums and here...this all seemed to start happening May to July 2008. Hmmm.
Comment by Guest, posted on Jul 25, 2008
Theres a little switch on the back of the part that connects to your xbox. try switching it to the opposite side then the screen should show up
Comment by Guest, posted on Jul 24, 2008
same here...my xbox 360 sounds great but wont show up on the tv
Comment by knighty209, posted on Jul 05, 2008
Same when i turn mine on the sound is fine but i cant see a darn thing anyone know what this is?
Comment by dubbz1400, posted on Jun 28, 2008
sound works fine..cant see anything though..tried new cables.. didnt work
Comment by nbamaster323, posted on Jun 23, 2008
i turn my xbox on and the sound works but nothing appears on the screen
Comment by Guest, posted on Jun 16, 2008
i had the ring of death thing and put it in towels and it is fixed but now when we turn it on it wont show up
Comment by Guest, posted on Jun 14, 2008
I turn my xbox on and the sound works fine but the screen just doesnt show up and i dont have the 4 red lights
Comment by rayne117, posted on Jun 10, 2008
When the 360 is turned on nothing shows up on the tv screen. I made sure the cables were all correctly connected. And the light for the AV cable source (the part where it is connected to the xbox 360) is red. Please Help!
Comment by liam565, posted on Jun 08, 2008
i turn my xbox 360 on and the screen stays the same i thought it was the cables but when i usually take them out the screen distorts but the screen stays blank and the 4 red lights telling me there is no connection come up, the the xbox works fine it speeds up for the game and i can hear it but nothing on the tv
Comment by Guest, posted on Jun 08, 2008
I turn on the xbox but its on but wont show on the tv what am i soppost to do?
Comment by Guest, posted on Jun 06, 2008
exactly the same as originaly described audio works fine and i can hear my games starting but cant see anything tried on 2 different tvs in high def and not high def the **** thing about this is i just got mine back 3 days beforehand after suffering red rings
Comment by Guest, posted on May 28, 2008
Everytime I turn on my console all I see is white lines running diagonal on the screen.
Comment by Guest, posted on Apr 16, 2008
I turn my xbox 360 on, and everything is working, but it doesnt show up on my tv's. I can hear the game playing on my tv, but i cant see it. I never had this problem before. I even bought a new wire for it. What do i do?
Comment by emsikay, posted on Apr 06, 2008
this system is ****. i specifically waited a few years before getting one because of all the problems i have heard about this system.. i got one in august.. of 07 now my screen wont show up...all i get are the white lines or dots or whatever they are. i still have sound though.. at least i can play a cd or somethin..this is bs.
Comment by Guest, posted on Mar 29, 2008
screne wont show
Comment by Hello People, posted on Feb 23, 2008
360 turns on with the sound and all but the visual effects won't work...
Comment by Trey990, posted on Feb 18, 2008
My xbox 360 has been working fine for about a year and a half. Recently, when i turn on my console, i can only hear the audio of the xbox, no video. I only see white lines running across my screen
Comment by Guest, posted on Feb 14, 2008
I can get my xbox 360 to turn on, it make noise and starts to show up on the tv, it shows part of the xbox loading screen then resets and does it all over again, it had gotten tipped over and now I can't get it to go past that
Comment by mimicheek, posted on Feb 13, 2008
My xbox was working fine i have had it for a little over a year, then yesterday the screen went blank. i can hear all the regular noises but no picture. I bought a new cable it still doesnt work.
Comment by ccwglove1282, posted on Feb 08, 2008
Hi, when I turn on my xbox 360, I can't get a visual on my tv. I get sound perfectly well. I've bought new cables and nothing, I've tried my console on another tv, still nothing. Help!!! What do I do?
Comment by Guest, posted on Feb 07, 2008
The screen at first was not displaying all the colors and graphics correctly. And now I just have the sound. I changed the cables and that worked for one session but now Its more of the same... Great sound blank screen.. I wiped down the plugs, switched inputs, and did some praying. No luck yet,
hey my bf has exactly the same problem, hes done everything possible to try and fix it. hes even borrowed his m8s leads and the console still wont show any picture. i think the only way to fix it is to send it bk to microsoft and pay em to do it
When i turn on my TV im sure that the cables are in the right places and all i hear is the sound.
i was playing and one day i turned it on and the sound worked perfectly but the screen dident come up i bought new cables and tried another tv but still nothing
Comment by Guest, posted on Jan 21, 2008
the same thing happened to me i turned on the xbox and the profile didn't pop out nothing but black i could only hear it.
why is that?
Comment by warrion03, posted on Jan 13, 2008
same thing with me i turned the tv on but it did not go on i tried the towel trick but nothing tried new tv still blue screen but the sound goes on perfectly. i dont know if its the tv or the xbox360.
Comment by Guest, posted on Jan 06, 2008
no image
Comment by Deadly Dr D, posted on Dec 29, 2007
My screen turned green, sometimes only in darker areas. The next day I go to turn it on and no video only sound and little white dots moving diagonally down the screen. I tried different cables and checked all connections. But I fear I have a bad video card.
Comment by jimmyjam1, posted on Dec 29, 2007
yes, i'm having the same problem. the cable connection seemed to be broken. white snowy lines moving across the screen so I tried another tv..same problem. bought new cables for the 360.same problem? how can i fix? help!
Comment by John JJ, posted on Dec 29, 2007
xbox 360 wont show a picture at all.
Comment by TazzT, posted on Nov 13, 2007
Same problem... keeps "trying to show up" with white lines coming across the screen and nothing more. There is sound. Have tried it on different TV's without any luck. Anyone any ideas?
Loading problems.
Repair Service
Find Video Game Console Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
