Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Red light on top is on
Performance light stays on,indicating full bag,NEW bag is in polace.Yet the light stays on and there is low suction.I have checked the hose for a clog,nothing there
  • 6 more comments
  • Anonymous Nov 18, 2007
    I have the same problem, Performance indicator light stays on even when old bag is replaced. No suction and cannot find any blockage.
    Are you getting suction through the hose? I had the same problem. My hose was clogged with a bottle cap and lots of dust and dirt. I cleaned out the hose and problem was solved.
  • Anonymous Dec 09, 2007
    I have the same problem; replaced the bag and now there is no suction. I opened it back up and ensured the bag was installed properly and it was. I'm going to try and clear the pathways as suggested
  • Anonymous Dec 20, 2007
    I have a clog in the hose..how do you clean the hose..cant unattach from the unit..only the base
    val
  • pompano Feb 09, 2008
    light stays on, with low suction, no clog
  • Melissa E Feb 22, 2008
    I too have the same problem. I cleared the hose and still have no suction. This is the first time this has happened, I've changed the bag dozens of times before.
  • Anonymous Dec 20, 2008
     I have the same problem. I changed the bag and the red light was still on. I found a sock stuck in the wabbly hose. I had to take the whole thing apart to find it.
  • Anonymous Mar 23, 2014
    keeps shutting off saying bag full but it is not full there is a light at the top on & i dont know what it means
    President:
  • 1,673 Answers
If you have something like a metal ball, drop it down one end of the hose to see if it comes out the other side. The hose, wands or the inlet in the power head, if any of these have a clog, that red light comes on and suction is low.
Posted on Jan 29, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
This problem could be very easy. remove the power mate from the rest of the vac. now in the hole where the wand should go spray a mild cleaning solution mixed with water. just spray a little. now take a rag and stuff it inside the hole until you can reach the other end of the rag by where the brushes are. grab each end of the rag and move it in and out (as if you are polishing a shoe) this might just do the trick. Dirt passing through this point gets stuck on the lens where the sensor is located and will cause this problem. Try not to pickup wet dirt and keep your brushes cleaned. if this does not work then bring it to your local Sears repair center.
good luck
Posted on Mar 28, 2008
There is a suction control on the end of the hose. Its a hole in the metal part of the hose (sticking out from the end) with a circular piece of plastic wrapped around it. I had not noticed it before, but once I covered up the hole, normal suction was restored.
Posted on Dec 02, 2008
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
The light on the top of the vaccum stays light and
You have a Electrolux, not a Guardian though, right? The light you are talking about is the bag full indicator. I know your bag is not full, so, try this. The knob on the top of the cleaner is a fine adjustment designed to let the bag fill up in different conditions, (dirt types) . So...turn the dial down to setting 2. Try it again. Did it work? If so, this is your adjustment . No need to ever adjust it agin. It is NOT the suction control. If this did not fix ya (haha) then, your adjustment diaphragm is bad and you will have to break down and bring it to Aerus(Electrolux) for a repair. I hope this info was helpful, if so, please leave feedback, it helps my rating, Thanks, Rene(The Vacuum Doctor)
Nov 07, 2009 | Electrolux Guardian Bagged Canister Vacuum
Keeps showing the bag is full
are you getting suction.check the hose at the end and see if there is suction.is your brush roller turning.no suction will tell it that its full please leave feedback
Mar 20, 2009 | Bissell 3522 PowerForce Bagged Upright...
Lost suction - Hoover Wind Tunnel S3630
You have a clog. The "bag full" indicator is nothing but a vacuum gauge, and impeding the airflow will cause a false indication of a full bag.
Clear your hoses and the air pathways behind the brushroll, and you will be back in business.
-R
Sep 27, 2008 | Vacuums
Red light won't turn off
You probably have a clog in either the hose, or the dirt inlet by the brush roll. That red light is telling you that either the bag is full or a clog is not allowing suction.
Mar 14, 2008 | Vacuums
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
check to make sure the bag isn't being sucked into the air filter. open the access door where the bag is and you'll see the air filter at the bottom. to check, leave the door open while you would see the performance indicator light on, and then pull up the bag. this is one of many solutions i'm sure to the performance indicator problem.
Oct 17, 2007 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
736 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
