Question about Panasonic Televison & Video
Panasonic dmr pwt520 disc tray will not open - Panasonic Televison & Video
SOURCE: Tray will not open
Thank you for your help, but like I stated, the rubber band, (belt) that drives the gear to open the tray is BUSTED. Found a place that sells them, will replace this week end. I don't think holding any keys down will open the tray, since it's driven by the belt from the tiny motor. Thanks.
Posted on May 04, 2007
  • 47 Answers
SOURCE: Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Posted on Mar 09, 2008
ltfrc
  • 227 Answers
SOURCE: My dad put a dvd
May be 4 to 6 screws holding on the cover. Remove the cover to access the disc.
Posted on Jan 17, 2009
  • 39 Answers
SOURCE: Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Posted on Mar 09, 2009
SOURCE: PANASONIC DMR-E80H "Change Disc Error"
This happened to me. I bought a new hard drive. Just got it today! It must be the exact same one. Maxtor, 80G 133.
See: http://www.pricegrabber.com/
Type in the above HD and you will find it. Once you get it and install it, it will automaticly format itself.
Posted on Jun 02, 2009
DMR ex83 disc tray not opening
With the unit turned off, press and hold the [STOP] and [CHANNEL UP] buttons on the main unit at the same time for about 5 seconds. (Ejection may take extra time depending on discs.)
DO THIS ON THE MAIN UNIT (NOT on the remote)
It worked well for me. Roget
Jan 27, 2014 | Panasonic DMR-E55 DVD Recorder
How do I select the recording speed "SP" mode on my Panasonic DMR-E55 DVD recorder
1 Press [< OPEN/CLOSE] on the main
unit to open the tray and insert a disc.
≥Press the button again to close the tray.
2 Press [W X CH] to select the channel.
To select with the numbered buttons:
3 Press [REC MODE] to select the
recording mode (XP, SP, LP or EP).
4 Press [¥ REC] to start recording.
Recording will take place on open space on disc. Data will not
be overwritten.
≥You cannot change the channel or recording mode during
recording.
≥[RAM] You can change the audio being received by pressing
[AUDIO] during recording. (Does not affect the recording of
audio.)
Feb 02, 2010 | Panasonic DMR-E55 DVD Recorder
DMR-EZ48V- DVD drive not working
Check Panasonic.com for Firmware updates. If it has a reset button reset it. Take off the cover remove dust and lint, also clean laser eye with rubbing alcohol. DO NOT LOOK DIRECTLY AT THE LASER LENS IF YOU PLUG IT IN, DURING THE OPERATION.
Sep 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
May 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Locked DVD Tray
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Panasonic dvd recorder
disk came off of the tray inside. unplug and open it maually.
Dec 03, 2007 | Panasonic DMR-E55 DVD Recorder
Tray will not open
put the machine in standby mode (ie switch power button on machine or remote) then, press and hold the STOP and CHANNEL UP buttons simultaneously. This will force the disk tray to open.
Apr 28, 2007 | Panasonic DMR-ES10 DVD Recorder
U99 code and tray won't open
Thats a reset code # its on page67 of your owners manual. Unplug the unit for a bit(5minutes) plug in turn on the power then turn off again then back on. If this dosent clear the code, contact panasonic at 800-211-PANA Good luck
May 09, 2006 | Panasonic DMR-ES30 DVD Recorder/VCR
Open Questions:
Televison & Video Logo
384 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
