Question about Dell Inspiron 6400 Notebook
RE:Dell inspiron 6400 problem in switching on
Thanks for reply yes I could see the DELL logo before diagnostic checks were started. For normal starting there is no display at all. I could feel some vibrations just next to the touch pad for two three seconds while pressing the power button and after that nothing.... There is no bios beep sound also.
  • haridas_otp Jun 02, 2009
    Thanks for reply
    The DELL logo is displayed only during diagnostic check. For normal booting logo is not displayed. Also can you tell me what is OSRI
    what should I do next? I couldn't get in to the Bios set up also.
  • Luis Perez
    Luis Perez May 11, 2010
    did you try getting to the BIOS setup ?
    Scholar:
  • 156 Answers
In that case, Try boting in safe mode by tapping F8 key as soon as u see Dell and it will give u advance boot option, when u get that , select Safe mode, and if you are able to boot to desktop , Go to device manager by Start>right click on MY COMPUTER>manage > on right Device manager.
Check under Display Adapter and uninstall whatever is under it, by making a right click on it and uninstall ,
But in case you are not able to see Desktop in safe mode aswell,  Only option is to do OSRI.
As your screen is fine as you can see Dell.
Hope this will work
Cheers!!!!
Posted on Jun 02, 2009
  • Karan Sethi Jun 03, 2009
    OK ,OSRi means , reinstalling everything back on the system, And if you see Dell , Your screen is working fine, so try tapping F8 on your keyboard once u see dell and you will get a list of choices, Try using Safe mode and Start>right click on MY COMPUTER>manage > on right Device manager. Check under Display Adapter and uninstall whatever is under it, by making a right click on it and uninstall , and if it does not work, Hold ctrl key on dell and keep tapping F11 which will restore the system to factory settings
Dell Inspiron 6400 driver speakers
Yes. There is an easy solution. Use the free Microsoft diagnostic scan and fix. It only requires three easy mouse clicks and Microsoft does the rest. CLICK HERE
Jun 08, 2012 | Dell Inspiron 6400 Notebook
The keyboard is frozen on the dell inspiron
Try removing any external devices first (Ex. USB devices) then run some diagnostic test:
1. Turn on computer
2. Tap F12 continuously on the Dell logo screen
3. Select Diagnostics
4. Wait for the test results (approximately 10-15min.)
If all test passed no problems have been found, it means there is no problem with hardware/computer. The problem is now pointing out to be software problem. Solution will be restoring it back to factory settings.
1. Turn on computer
2. Tap F8 continuously on the Dell logo screen
3. Select Repair computer
4. Follow instructions... then select "Dell Factory Image Restore " on the recovery options
5. Follow instructions
6. Wait for 20-25min. and computer now is back to factory settings
Hope this helps
Nov 14, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
hi there so once you see the dell logo keep on tapping f8 and check if you can enter the safe mode, if not tell me the lights because that means thats its a no post issue and we might need to reseat your memory.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
DELL inspiron 6400 not switched on
This is a no boot issue. Youre saying that you can perfectly run the PSA diagnostics but doesnt load Windows rather it stays on black screen, meaning the boot loader of Windows failed to load. You need to reinstall windows on your computer
Facing problem with battery of Dell Inspiron 6400
1. Shut down the system, remove the battery and the Ac adapter from the computer.
2. Press the power on button for 10 seconds
3. Reinsert the battery
4. Power on the computer and as soon as you see the dell logo press the f2 key a couple of time
5. Using the up down arrow keys , go to the option that says battery info. If there is an error message listed kindly post it back
6. Otherwise shut down the computer reconnect the ac.adapter and check if the problem is solved
Also the battery has a diagnostic lights on it , remove the battery from the computer and press the button on the battery a set of lights would glow. If they are steady and come in a series the battery is good , If some lights are missing the battery is bad and may need replacement
Thanks
Proton
May 15, 2009 | Dell Inspiron 6400 Notebook
Touchpad
Hi Ayubehenzo,
You will need to run 32 bit dell diag's.
You would need start the pc and the tap F12 button on the Dell Logo. Select the last option diagnostics. On the option where it says that were color bars displayed type "N" once the tests are done press "N" where it says do you wanna continue the remaining memory tests. Once this is done you will get a message loading dell diagnostic utility partition. you will now need to choose the custom test and then need to run a test on the touchpad. If this still doesnt resolve your issue you will need to call Dell Technical Support.
Nov 12, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Screen turns black Problem
Could you please run the diagonistics on the computer?
Turn on the computer. When the DELL logo appears, press <F12> immediately. Select Diagnostics from the boot menu and press <Enter>.
NOTE: If you wait too long and the operating system logo appears, continue to wait until you see the
Microsoft Windows desktop. Then shut down your computer and try again.
b Press and hold the <Fn> key while powering the system on.
Make a note of any errors that you get after running the diagnositcs on the computer.
Mar 08, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
162 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
