Question about AudioControl Overdrive-grey 2 Ch Line driver / Preamp-grey
Audiocontrol i got a 12'' kicker L7 4ohm dual voice coil in 1.30 cubic sealed truck enclosure in regular cab chevy silverado i'm thinking of adding on a epicenter and i would like to know what is the difference between the audiocontrol and the soundstream bx12 other then the price will any of the work on my sub
    President:
  • 1,114 Answers
The Audio Control unit is a considerably better built unit. PC boards are millitary spec. Thick and hearty! will not self destruct like alot of chinese stuff... The epicenter is a phenominal piece of electronics for anyone who loves bass as well as Rock. older recordings lack the intensity in the lower end response by comparason to todays "pop" music. A suggestion though, if you listen to Rap, this unit will cause your sub to over excurt and wear out quickly if not blow. I can't really speak to the Soundstream unit. I was a Soundstram Dealer when it was still a US company. All that's left of the original product is the name. Hope this helps
Posted on Jun 03, 2009
Don't know how to wire a kicker solo-baric L7 2 ohm dual voice coil 12 inch sub
Wire in series for 4R. +ve of coil to amp +ve. -ve of that coil to +ve of second coil and the -ve of the second coil goes to -ve of amp.
Aug 10, 2017 | Car Audio & Video
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
I have 2 12 inch kickers and have a solid box in my mustang. would it sound better if it was ported?
Kicker speakers always require very large boxes (you're looking at 12 cubic feet for both), when ported. Ported boxes are very sensitive to box size, port tuning etc, so it's probably best to leave it sealed, as they are far more leniant, and sealed boxes are usually 1/2 size of ported boxes. You would get less bass when ported than with sealed (because ported boxes must be bigger to match the sealed ones).
If you wish to experiment with the bass response of speakers, download winISD, and put your speakers in, see what size boxes give you what.
Jan 09, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Kicker 07DCVR122 Dual 12
get a 2 channel with as much watts as you can affored. you wont blow them its better to have to many watts then not enought the subs work harrded with less watts i know that sounds crazy but trust me je
Nov 13, 2009 | Kicker DCVR122 -- 2 Ohm Dual 12in CompVR...
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
MTX 5500 SLEDGEHAMMER 12" ENCLOSURE
According to MTX they need 1.25 cubic ft per sub sealed and 2 cubic feet vented. Most pre-fab boxes will work for those subs.
Jan 06, 2009 | MTX Dual 12" Subwoofer Enclosure (Bs212s)
Best sub For RF T10001
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Dec 13, 2008 | Rockford Fosgate T10001 bd Car Audio...
What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 85 dB
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    AudioControl Overdrive-grey 2 Ch Line driver / Preamp-grey Logo
    101 people viewed this question
    Top AudioControl Car Audio & Video Experts
    xxxxxx xxx
    Are you an AudioControl Car Audio and Video Expert? Answer questions, earn points and help others
