Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Water water everywhere
Drip pan runs over daily
    Novelist:
  • 103 Answers
Hi: I don't think your defrost water is even getting to the drip pan. It just flows where it can get out with the least resistance. You are on the right track though. Your defrost drain is probably plugged, with mold (as it's not refrigerated) or a tid bit from the freezer. You should not have to remove any parts but the bottom bin in the freezer. Look behind it you will see a rectangular shallow funnel at the very bottom of the freezer. There is a hole in the center of it. Snake it with a pipe cleaner or just pour a strong solution of water and clorox in it (about 1/2 cup) or both. That will give the defrost water back its normal path to the tray instead of leaking of your floor. I hope this helps, Jeff
Posted on Jun 03, 2009
Whirlpool side by side full drip pan
The condenser fan should be running whenever the compresser is running. With all of that condensate, I would look at your door gaskets. If they are leaking and you are in a high humidity area you will produce more condensate than what the pan can Handel. Then again. If the compresser is running the heat from the discharge line should evaporate the water with ease. I would look at the seals possibly leaking and ignore the full drain pan.
Sep 08, 2012 | Whirlpool Refrigerators
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Excessive water is dripping inside the refrigerator. Ice maker is disconnected. The water has to be from condensation. The drip pan in the bottom of the refrigerator is dry and it apprears the water is...
Their are 2 possibilities
1) Freezer door gasket not sealing...if that were the case frost would form everywhere in freezer espically on shelves and packages of food
2) the defrost drain is frozen over...its behind the back plate of freezer under the evaperator coil
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
We live in an apartment complex and have a Trane Air Conditioner, each unit has its own central air. I believe the one in our unit has clogged drain pipes, when we first moved in we didnt change the air...
Hello You have to cut the pipe and blow out each end,You can use a 1"rubber hose from an auto parts store & 2 hose clamps, If you can't find the end.This will allow access in the future to clean out the pipes.It will slip over 3/4" PVC pipe.They sell a PVC pipe cutter but a hacksaw blade works well.Get ready for all the water in the pan once you cut!
Sep 14, 2010 | Heating & Cooling
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
PUMP WILL NOT STOP WHEN YOU PUT POWER ON . PUMP STARTS AS SOON AS YOU PUT THE POWER ON TO PICK A WASH PROGRAM EVEN BEFORE THE DOOR HAS BEEN CLOSED.
I have seen this on my unit. There was water in the drip pan under the dishwasher. Water in the drip pan comes from a leak. In my case, the water valve was getting so old that it was letting too much water into the unit when it was trying to fill. This cause the filling station to over flow into the drip pan.
A quick fix - I removed the water from the drip pan under the unit and I was able to turn down on the supply valve in the basement to limit how much water could come in. This allowed the unit to run without overflowing. I will replace the water valve soon.
Other possibilities, the float device used to detect too much water in the drip pan or too much water in the unit is stuck in the too full position. Or the pump out pump is stuck and not moving water.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Apr 24, 2017 | Frigidaire FSC23F7D Side by Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
147 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
