SOURCE: Garmin C340 battery not charging
The Garmin batteries tend to die after about 2 years. Garmin will replace the battery for you but prepare to pay top dollar. It is a shame because the problem is commonplace. They should have made the replacement user friendly. The battery is buried deep inside and it is soldered.
SOURCE: dead battery- willnot charge with supplied charger
my c320 has a dead battery-how to change?
SOURCE: Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
SOURCE: Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
SOURCE: Garmin C530 won't power up. I fully discharged
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
