I have a 2003 nissan altima 2.5L. When I turn the air condition on, it makes a loud noise and grounds and even shakes the car. After I turn the air condition off, the noise subsides. You still hear it somewhat. What do I do. I don't want to spend a fortunate to fix it but I want to be cool this summer
I had same problem turned out it was the bearings in ac compressor pulley.cut ac belt off. get new bearings installd in pulley.
When you put your A/C on, there is Vacum Motor or Solonoide, that increases RPM of the Engine to compensate the load of an A/C. If the vacum hose is leaking or raptured the RPM of Engine remain low and Engine Shakes. When you put the A/C on and the RPM of Engine Increases, but a little, then your Selonoide is working but not adjusted properly, so adjust it for the proper RPM of the Engine. Put all the loads on, I mean Head Lights and A/C on and then ajust the RPM.
