Question about Garden
Can not get the head off, the bolt spins.
The head on the weedeater would not spin when i pulled the throttle trigger. I took the motor off the back of the shaft, and now I can't get the head off. when I try to take the bolt out of the head it spins. what can I do to fix this problem? How do I get the head off?
  • 41 Answers
You should not have to take the head off.You should be able to pull cable out through the top.
Posted on Jun 03, 2009
    Habit-Forming:
  • 8 Answers
On a lot of the Inexpensive "Harry Homeownwer" weed trimmers
the Manufacturers will disable the ability to remove the trimmer head
from the shaft. Reason? Theirs is that your paying less than $200.00
dollars for their trimmer and they make more by selling you the replacement shaft assembly then by making repair parts available.
Factory Warranty repair shops will tell you to take the unit back to where you purchased it as long as it falls within the 90 day warranty
date or the period of extended coverage. Why? The warranty repair shops charge as much as $50.00 dollars per hour labor not including parts. The shaft assembly is almost $75.00 dollars before labor, add parts and it exceeds the cost of replacing the unit with a brand new one. Big Suggestion: Keep the box and all supplied instructions, place them in a plastic bag along with the original bill of sale and certificate of coverage for an extended service warranty, staple the
bag to the inside of the box and keep all nearby in case of unit
breakdown. Makes life a lot easier, and if you think this is a hassle
then spend the extra money to purchase a unit that can be repaired.
Posted on Nov 21, 2013
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Weedeater SST25 head not spinning
At the base of most weedeaters there is a mounting point where the coil that extends down and through the shaft to the head is. It "sounds" like over time it may have finally rattled loose. I know on my weedeater, every season I used to take apart the head and take the shaft completely off, tighten things up and then reassemble and I was usually good for the spring/summer. It's amazing at how much vibration those things can generate and that usually spells loose nuts and bolts by the end of the season.
Sep 30, 2013 | Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Ryobi 975R head won't stop turning.
sounds like the idde is to high
Aug 06, 2012 | Garden
My TB70SS cranks and runs perfect! The problem is the clutch seems to not engage. The head will spin at idle speed, but, when I pull the throttle trigger, it seems to bog a bit, and the head almost quits...
There may be an issue with the clutch or the clutch drum. Some disassembly may be required if the string head doesn't spin quickly when accelerating the engine. The clutch itself is threaded onto the crankshaft of the engine near the handle end and the clutch drum is screwed into the end of the crankshaft. If you can disassemble to that point, you will be able to diagnose your clutch problem...maybe it is worn severely and needs replacing.
Aug 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
Weedeater gas TE400. Trigger broke (perhaps
120' cord. I would go to a big-box store and investigate making your own cord so that you only have 2 ends. 12 guage at the very least. any thing smaller, and you will burn up the motor.
I believe that the trigger and throttle cable should solve your issue.
530071550 throttle kit $8.16 + 12.75 shipping
Nov 07, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
How to take apart pull rope for weedeater edger
If the recoil is in the front, the engine has to be removed for access to the pull start assm. Start taking the bolts out in the back and work your way forward. Use a coffee can or a large pan to hold the bolts. You will use hex key drivers that are like the allen key sets. The hand grip with the throttle trigger holds the front of the housing. The grip has two coarse threaded cap screws which hold it to the shaft. Before you tear it all down, try shooting some wd40 or similar down in around where the pawls grab the flywheel. Maybe the drum is just stuck against the flywheel and after a little lube will free up and be ok?
Aug 21, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Washer won't spin.
From Howtomendit: key point I missed was that you need to pull the motor apart after you have taken it out of the machine before you can get access to the screws holding the brushes in. (ie: unscrew the four bolts). Not as difficult or scary as it looked!
please read thro first.
first unplug it, pull it out so you have some work space, take off back plate, remove belt undo (should be white rectangle plastic block with wire attached), remove green+yellow wire undo bolts which hold motor to drum, gently ease out motor (please be aware of sharp edges), run screwdriver down 1 side of motor so you put it back together same way you took it apart, unscrew 4 bolts that hold motor together take top bit of dont loose spacer ring, place to 1 side, remove middle comutator the end the brushes are touching will need a proper clean wd40 maybe wipe clean with cloth so its not dull let dry, undo carbon brushes, take plate off also clean then clean what they were attached to when dry replace in reverse order gently (with new brushes) then replace back on machine plug back in and test by running spin program found at bottom of dail if i have my mod/num right let it get to full spin watch motor if it sparks an looks like blackpool illuminations motors no good will need new 1 sorry.
image_icon_name.gifsteven
Dec 15, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Garden Logo
431 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
