The bright light signal is always on and it flashes and the brake light is always on and the ABS light is always on what does this mean
The amber ABS warning light is telling you that there is a problem with the ABS system. When the antilock brakes don't work you just have good old fashion non antilock brakes. When the red brake warning light is on it could be a couple of things. (unless you are talking about the brake light on the back of the car is stuck on) the red brake warning light on the dash tells you when the parking brake is on and it also tells you when there is a problem with the hydraulic system. Some cars will also turn this light on when the brake fluid is low, (not sure if the Cavalier does this)
The ABS system is computer controlled and needs to be scanned for trouble codes to diagnose the problem.
I can't say I have ever heard of a "brights" indicator flashing, Do the headlights go bright and dim as it is flashing? Is it a slow on and off like a turn signal or faster than that?
SOURCE: No rear brake light / turn signals on 2001 Chevy Cavalier
The problem is the turn signal/headlight/hazard switch assembly on the steering column which the brake light wiring runs through. The part is easy to change and cost about $50 at most parts stores
SOURCE: 2005 CHEVY +TRAIL BLAZER ABS AND BRAKE LIGHTS ON
if chains caused problem and you have driven with them off light would have gone out once it saw everything working properly. look at sensors might have pulled a wire loose with chains. the abs system runs a self test everytime you start vehicle if it sees a history code from last time it will leave light on and look to see if that problem still exists and 99% of the time it will cut light off . but need to have scanned and checked out
When the ABS light is on when driving there is a problem in the anti lock brake system and you will need to have it tested to find out what the problem is. As long as the light is on the ABS has been shut off by the computer until it is repaired. There could be problems with one of the wheel speed sensors, wiring or the ABS pump. On some vehicles the red brake light will come on too.
SOURCE: my abs light is always on and now my brake warning light is on but brakes seem to be working fine
The ABS light is a warning that you have an issue with the ABS system. The red brake warning lamp is serious. It is telling you that there is an issue with the base brakes. Your car will be ok with an ABS light, but the red warning lamp could be really dangerous. You should have them checked ASAP. It could be from many causes. A park brake switch, low fluid, the causes are too numerous to list. Please for your safty have it checked. Good Luck
SOURCE: Chevy Cavalier 2001 ABS Brake problem
You don't say what brakes.
I have had many cavys and worked on them. Great cars.
Your problem sounds like a **** rear wheel cylinder and bad drums/rotors and abs sensor wire.
My car just did everything you describe, I put in new wheel cylinders, drums, brakes, rotors, and 2 new rear brake lines. For less than 200 bucks the car is like new again and has well over 100k.
You can do it yourself. Doesn't take special tools. I followed online how-to's.
