Question about Xerox Phaser 8400 Laser Printer
Just moved printer, after cool down for 1/2 hour. Now error code 37,004.40:139096 - service needed appears... help....
Just moved printer, after cool down for 1/2 hour. Now errod code 37,004.40:139096 - service needed appears... help....
    President:
  • Xerox Master
  • 1,447 Answers
Your printer thermostator paper dust or toner dust clean it and solve
Posted on Jun 03, 2009
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
Error 5100
Issue: ERROR: Service error 5100 appears while printing from the computer
1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP180 may require repair
Try the above..
Oct 18, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I had a problem start with error code E000-0120. I easily found this was an overheating problem. The room where the printer was located had gotten very hot, so I shut the printer off and left it until...
these means that thermistor still reports the temperature problem or that copier was memorised the error code and keep reporting it. Auto shut off is sign of fixing trouble.
To be sure if the thermistor or lamp is faulty, first try under service mode to clear the error.
If that doesnt help you you need to call service to locate problem in fixing section.
Procedure to clear error:
Clearing E000
1) Start service mode, and select 'FUSER' under 'FUNC'.
2) Press 'E000RLS'.
3) Turn off and then on the power switch.
SERVICE MODE:
1) Press the "*" key on the control panel.
2) Press "2" and "8" on the keypad at the same time.
3) Press the "*" key.
Hope that helps!
Aug 10, 2010 | Canon CLC 4000 Copier
I have a ip5000 that has service error code 5100
I had the same problem. all i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine.
Tips:
#1 Move the cartridge holder back to the right manually, but carefully - close lid and turn the printer off, then on again.
#2 Move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Aug 10, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Phaser 8400 error code 37,004.40:51402 this happened after moving the printer Thank you
Hi abonk:
This is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the
supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Your preheater needs to be replaced.
Xerox Preheater Part # 119641980
This part will have to be replaced by a certified Xerox technician.
Hope this helps
Jun 23, 2009 | Xerox Phaser 8400 Laser Printer
Alarm light blinking, cartridge carrier won't move
Hi
Ok please try this
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Not workin'
I assume you've checked and done all the basic things like a power down and power up reset and checked to make sure all the ink cartdridges are properly installed and seated.
The user manual discusses your error message and suggests you do the following: Open the scanner unit to make sure any tape securing the ink cartridge holder has been removed; close the scanner unit/ press the ON button to turn off the CX6400, then turn it back on . If the error message still appears, contact your epson dealer or Epson tech support. If so,then you may want to get direct support and information from Epson at this website : http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&restart=yes
Technical Support line_dkblue.gif spacer.gif United States Phone Number:
(562)276-4382
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT) Canada Phone Number:
(905)709-3839 Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Sep 23, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Motor throtting
This error appears when the printer has worked for more than 1 hours continuous, and to protect the printer. Wait a few minutes for printer to cool and continue with your printing.
Jan 22, 2008 | Datamax I-4208 Thermal Label Printer
900.00 Service
When I have seen this error in the field, I have cured it by updating the firmware. Lexmark has a paper in their Knowledge Base on 900 errors:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:556:0:0&framed=&docid=ENUS22164&relevance=1
Go through the suggested steps to try to narrow the problem down.
But if it needs a firmware update:
http://support.lexmark.com/printerfirmware/
Use code: Isfap129 to download the package the C530dn.
Hope this helps!
Nov 29, 2007 | Lexmark C530dn Laser Printer
Xerox Phaser 8400 Laser Printer Logo
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
