Question about Toshiba E-Studio 161 Copier
C390 on Toshiba e-studio 2500c
What does a C390 code mean on a Toshiba eStudio 2500c and how can I clear it?
How do I remove error code ce60?
Error ce60 e-Studio 2820c - Fixya
www.fixya.com/support/t17213833-error_ce60_e_studio_2820
Mar 19, 2013 - So I put in the code 8 clear/stop so it will show the error code. No error code is popping up. The number 8 just stays on the screen, like nothing ...
Jan 27, 2015 | Toshiba E Studio 2330c 2500c 2820c Copier...
Resetting the counter on a Toshiba e studio 2500c
I reached the total print counter 109219 and want to re set.
Oct 23, 2012 | Toshiba E-studio 2500 cbc939390, Copier,...
I have a toshiba estudio 2500c. I have error code C3B0. How do I fix it without calling a service person?
I have a toshiba estudio 2040c. I have error code C3B0. How do I fix it without calling a service person?
Sep 08, 2011 | Toshiba E-studio 2500c Color...
Hi, I have a Toshiba e-studio 2500c Color Copier. All of the sudden I've got a few errors. First a C390 then a CA00, but I was still able to make B&W copies, now I've got another error C970 and...
you seem to be having some issues ... ... ... the codes you are getting are related to the color calibration. possibly with the cyan developer unit or the high voltage board. to properly diagnose and fix the problem you will need a technican to fix the problem
Jun 22, 2011 | Toshiba e-Studio 350 Copier
Error code C970 on my toshiba e-studio 2500c. Sais call for maintanance...Can I clear this or fix this on my own?
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
Jun 08, 2011 | Toshiba e-Studio 350 Copier
Toshiba eStudio 2500c - CA00
This is a pretty complicated issue/problem. there are 5 pages devoted to this issue in the service manual. This issue would be best handled by a technician. but you could try the following....
[CA00] Color registration abnormality
<Color toner low density>
Turn on the copier holding down 0 and 8 and wait till it boots up into its service mode..then enter code 2692 “Prevention of color toner low density / change the zero to 1.
Then change code 2693 “Prevention of color toner low density / Judged number of sheets setting” value to 40 (default 20).
Make sure you have cleaned the main charge units by fully extending the rods with the green handles for each color.(open the front door) and use the plastic wand attached to the front door to clean the laser glass for each color..there is a small **** under each color unit to slid the wand into..felt side down on the wand.
Like I said there are several other complicated ways of fixing this.
Jan 15, 2010 | Toshiba Office Equipment & Supplies
Toshiba estudio 2500c C-448 (445) error codes
Did u clear the status counter ?
After repairing the matter which caused the error [C448], perform the following:
(1) Turn the power ON while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press the [START] button.
(3) Change the displayed current status counter value "32" to "0", then press [ENTER] or [INTER-
RUPT] (to cancel C448).
(4) Turn the power OFF and then back ON. Make sure that the equipment enters the normal status
Jul 20, 2009 | Toshiba E-Studio 161 Copier
C448 on Toshiba e-studio 2500c
C448 indicates Heater lamp lights continuously for a certain period of time when the pressure roller temperature during ready status is higher than the specified.
1. Clear status counter
Enter 08--> 400 --> change the value from "32" to "0", press Enter and restart MFP.
If occur again, u need to check followings:
1. Check the power supply and fuser unit
2. Check the LGC board
Feb 04, 2009 | Toshiba E-Studio 161 Copier
Toshiba E-Studio 161 Copier Logo
702 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
