Question about Canon imagePROGRAF W7250 InkJet Printer
E0 2D01 Error @ Power On
This printer (W7250) has been sitting at a friends for at least a year since last used.
I have successfully downloaded and installed the driver to my OSX 10.4 and this thing won't get past the (EO2D01 "Turn Power Off!") error when power is turned on?
Any suggestions?
THX
  • 121 Answers
SOURCE: Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
You'll probably need to replace the whole printhead.  It's a bit of a job on that machine
Posted on Oct 27, 2007
  • 240 Answers
SOURCE: Showing printer error 6A00
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on May 19, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
  • 23 Answers
SOURCE: error message after copying 5100
This error takes place when a encoder sensor is dirty on a back side print head.
Posted on Jun 22, 2010
SOURCE: After installing Mac OSX 10.6
Hi l_denomme,
try updating the drivers of your printer, mke sure that you donwload the driver compatible for a Mac to make your printer work again.
I hope this helps.
mvincentc
Posted on May 15, 2011
ERROR 5B00 IP2770
How to Reset printer canon ip2770 (E 5B00) ip2770.jpegIP2770 Resetter v1074 I have tried. IP2770 Resetter was sent by our friends in Jambi, and hopefully this iP2770 Resetter runs perfectly. Resetter is free passwords ... and FREE
How to Reset Canon IP2770 Error 5B00
Download Canon iP2770 Restter v1074 free pass Here
(Do not forget to turn off the download manager, for a successful download)
Go to the iP2770 Service Mode:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
V1074 iP2770 Resetter Then run it:
1. Prepare 2 blank paper in the printer
2. In the menu "Clear Ink Counter" click "Play" and "Platen"
3. Click Test Print ... Done ...
(In some experiments sometimes "platen" unable / err message appears, but no problem, still can work well)
Hopefully Successfully
Nov 26, 2010 | Canon Office Equipment & Supplies
POWER CORD AND CORD TO COMPUTER
1. You can find any Electrical Shop. Find 2pin power cord.
2. You can find any printer's USB Cable any computer reseller
Thanks
Sk. Abdus Sabur
Nov 30, 2009 | Epson Office Equipment & Supplies
No ink is getting to printhead in imagePROGRAF w7250
Your printheads are indeed clogged. (Note: all ij printers should be powered off when not in use! This retracts & seals your printheads.) Now, on to your problem. In your printer software, there should be a maintenance section. In there, you need to clean the printheads - this may have to be done *many* times - like 10-ish to clear (if still possible) clogged ink.
Hope this helps.
Cheers,
gurutim
Mar 19, 2009 | Canon imagePROGRAF W7250 InkJet Printer
How do you change the ink tanks in a canon image prograf w7250?
The website does nnot show the 7250 but does show two other w models. Maybe the manual for one of those wil show how to change the tanks.(see guides and manuals).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=260&modelid=11264#DownloadDetailAct
Jan 21, 2009 | Canon imagePROGRAF W7250 InkJet Printer
I did not see that there was a response on Apple's support site that adds to the previous post I mentioned. Combing the steps from the two posts, I was able to get our W7250 to print from Mac OS X 10.5 Leopard.
Here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard :
1. Download garo34 print driver from Canon's support site here.
2. Download the iPF610/iP710 Leopard print driver from Canon here.
3. Double-click on the garo34_osx.hqx file that you downloaded.
4. A folder named Driver is created; open it and double click on "GARO Installer for X".
5. Enter a name and password of an administrator account on your Mac and click OK.
6. When the GARO Installer for X window appears, click on Continue.
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
11. When the installation is complete, click on the Restart button.
12. When your system has restarted, double-click on the iPF610_710_Driver_OSX_10.5_Ver1.10.hqx file you downloaded.
13. A folder named iPF610_710_Driver_OSX_10.5_Ver1.10 is created; open it and double-click on "iPF Driver Installer X".
14. Enter a name and password of an administrator account on your Mac and click OK.
15. When the iPF Installer X window appears, click on Continue.
16. Click Agree.
17. Click Install.
18. When the installation is complete, click on the Restart button.
19. When your system has restarted, click on the System Preferences icon on your Dock or select System Preferences from the Apple pull-down menu.
20. When the System Preferences window appears, click on the Print & Fax icon.
21. Click on the + Button underneath the Printers column.
22. Another window will appear; click on the "More Printers" icon.
23. A drop-down window appears; select Canon IP (GARO) from the pull-down menu if not already selected.
24. In the "Printer's Address:" field, enter the IP address of your Canon W7250 printer (e.g. 192.168.1.2).
25.In the "Queue Name:" field, enter a name for your printer (e.g. W7250).
26. Click on Add.
27. The W7250 is now your default printer. If you want another printer to be the default, change it in the Print & Fax preference pane.
Voila!
I hope this solves your problem and you found the instructions helful.
Mark
Jan 09, 2009 | Canon imagePROGRAF W7250 InkJet Printer
Upgraded to Leopard and now need to update my printer driver
Canon will not be coming out with a Leopard print driver for the W7250.
However, here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard:
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
16. Click Agree.
17. Click Install.
26. Click on Add.
Voila!
I hope this solves your problem and you found the instructions helpful.
Mark
Sep 11, 2008 | Canon imagePROGRAF W7250 InkJet Printer
Error EO 2400
What about the manual -no help there? Canon Technical Support is the next place to enquire.
Aug 13, 2007 | Canon imagePROGRAF W7250 InkJet Printer
Canon imagePROGRAF W7250 InkJet Printer Logo
208 people viewed this question
old marine
old marine
