Question about Sewing Machines
Bobbin I have a white model 764. I just started a new project and my bobbin thread will not interlock anymore with the needle thread.
  • 1 more comment
  • Officebarbie Nov 08, 2007
    Okay, I have tried the new needle, blah blah blah. How does a person time their machine?
    If you can help me with this thank you soooo much!
  • rifka1 Oct 10, 2008
    I am having the exact same issue. Tried the new needle, still no luck. How do you re time your machine?
  • Rebbecca Bellemare
    Rebbecca Bellemare Feb 08, 2012
    I also just encountered this issue. :|
I have the same problem, how do I retime my sewing machine
Posted on Jul 13, 2008
Thread started bunching on underside of project & tangling around bobbin. Now the needle won't pick up bobbin thread, even after changing needle 2x and re-threading upper thread. What's wrong?
Hmmm, could be several things.
Try a brand new needle. Try a different brand of thread.
Remove the top thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still will not pick up the bobbin thread, the machine could be out of time.
Jan 19, 2018 | Singer Sewing Machines
How do I thread my white mode 742 also bobin thread is not picking up
Sewing Machine 101 The White 764
White sewing machine model 742 sewing discussion topic PatternReview com
Instruction Manual White 742
Even though the following is not your particular model, the process is very similar from one machine to another, so what you aren't able to get from the above links, you may get from these. Be sure to ALWAYS RAISE the presser foot when threading the top thread so the thread will seat properly.
White Sewing Machine 639 How To Upper Thread The Machine Vintage Metal
White Sewing Machine 639 How To Wind Bobbin Front Loading Bobbin Vintage
Nov 18, 2017 | Sewing Machines
Model 4075 white sewing machine thread from bobbin builds up and stops sewing.
Check the stitching and confirm that it is in fact bobbin thread and not the top thread that is creating knots & loops under the fabric. This is usually the case and is called thread nests or bird nests. (You can search the internet for more information about this symptom.)
Install a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE the presser foot while rethreading the upper thread.
Confirm the thread path is correct.
Verify the bobbin is installed facing the correct direction in the bobbin case and the bobbin case is threaded properly.
Set the upper tension to the midway point (factory standard) although it may need to be tweaked as machines change with use and time.
Pull up the bobbin thread. This method works with general sewing projects, not just quilting.
How and Why to Bring up the Bobbin Thread
Begin to test sew slowly.
If the thread is still making a mess, then the machine most likely has a timing issue. There are multiple web sites and videos that discuss sewing machine timing. Or take it for service.
Sep 30, 2016 | White Sewing Sewing Machines
I need help with a white sewing machine model 765 I can't get it to sew it doesn't pick up the bobbin thread
First thing to try is a brand new needle. A bent/damaged needle may not be able to pick up the bobbin thread.
Otherwise, it is possible it has a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to connect with the bobbin thread. Search the internet web sites and videos. There is a lot of information on how to fix sewing machine timing. Or take it for service.
Jul 11, 2016 | White Sewing Sewing Machines
Toyota quiltmaster
ALWAYS RAISE the presser foot and rethread the top.
Be sure that your top thread follows the correct thread path.
Set the top tension to the midway point.
Re-test your machine.
Tension is a tug-of-war between the top and bobbin threads. Correct tension is when both threads meet in the middle of the fabric. If the bobbin thread is laying on the underside of the fabric, the top tension needs to be increased so it will pull the bobbin thread up into the fabric. If the top thread is pulling the bobbin thread up to the top of the fabric, then the top tension needs to be loosened.
FWIW, thread tension is not static. Tension will need to be adjusted probably every time you start a new project. Test it on a piece of scrap fabric from the project and adjust it BEFORE beginning the project. Remember to change the needle often--probably every time a new project is started or every 8 hours of sewing time. Be sure to use the correct type and size needle based on the fabric & thread you are sewing. Also, AVOID old or bargain bin thread!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
All About Needles SCHMETZ Needles
Nov 24, 2017 | Sewing Machines
I need a manual and a bobbin case for a new home model 764
I don't know if the link will work for the bobbin case, if it doesn't
go to
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
Jun 09, 2012 | White Sewing Sewing Machines
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
I have a brother sewing machine. i threaded and have rethreaded and threaded the bobbin over and over. it will not move the fabric and botton thread will not catch onto top. what am i doing wrong?
Brother machines are usually a very good brand. Sounds like you are having a small problem with threading..........I know how frustrating that can be!
Start over....totally from the beginning. First, clean the machine of all dust, I use a small paint brush to remove lint from the bobbin case area. Oil the machine. Remove all the thread from the machine, use a different bobbin and rewind it with new thread. Make sure the bobbin thread is the same as the thread you use to thread the upper needle with. Use a new needle that is the appropriate size for your sewing project. Check to make sure the feed dog is moving when you turn the wheel that raises the needle up and down. New needle, new bobbin, new thread......before you place the fabric under the presser foot (and with the presser foot raised), turn the wheel one complete rotation to allow the upper needle thread to catch the bobbin thread. Gently pull both threads out towards the back of the machine, making sure the bobbin thread is now coming up through the little hole in the feed dog plate. Place fabric under the presser foot, lower presser foot and as you slowly start to sew, make sure you have the bobbin thread pulled with slight tension out from the back of the needle. This will take up any slack in the bobbin thread and keep it from making a knotted mess. Good luck, I hope this helps.
Feb 13, 2011 | Sewing Machines
The needle is not catching the bobbin..
A bent needle or one not seated is common problem. Also the orientation of the needle is important. Make sure the flatted part is where it should be seated.
The rest of problems are usually a tension problem. As the needle comes back up, a loop should form that is caught by the shuttle and carried around the bobbin.
Sep 22, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Sewing Machines Logo
256 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
