Replaced horn cover so had to disconnect battery and take out main fuse,now have put it all back and have no ignition lights
SOURCE: lits horn but will not start
dose it turn over? if not sounds like a problem with starter solinoid attach jumper to + term. other end touch to starter main wire see if starter turns
SOURCE: have an 02 harley deuce. Ignition on but the fuel
Hi, you can check out the clutch switch and the kick stand switch. They are also factors to consider when fuel pump does not prime..
SOURCE: Deuce turn signal not working
Possible fault with the switching unit. Please check the line to the switcher unit from the hand control switch and if this is good then the switcher is faulty , if not the cluster switch at the hand control can be faulty.
SOURCE: I have a 95 1200 sportster with no electrical power
Check the wiring in the handlebar controls. It's very possible you pinched a wire. Also check the tailliight wiring inside the rear fender.
