Question about Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 - Acer Arcade Deluxe Problem
Hi, I am not able to boot using vista since I accidently pressed the arcade button when my laptop was switched off. It started with installing something which I okayed and since then it has never booted up in vista ever again. I have similar problem but nothing worked. Even in safe mode, I see blank screen and only mouse cursor.
Have you checked your bios settings are you booting from the right drive have you tried recovery?
Posted on Jun 02, 2009
Hi, system will only boot up by pressing the top media button and of course that brings up acer arcade. If I exit Acer arcade the systems says in is hibernating windows. F8 interupts the boot up but...
How long have you owned the laptop and how long have you had this problem? Is the hard drive still recognized? Do you have a windows installation disk that you can put in the laptop and boot from that disk? Your best option is to reinstall windows. If you need to backup data you will have to hook up the hard drive to another computer. There are several options for doing this. If this is beyond your level of expertise you may want to consider having a professional look at it. If it is still under warranty then you would want it serviced under warranty. Once I have more information I will assist you further.
Thank you,
Lee
Dec 03, 2009 | Acer Aspire 6920 Notebook PC
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
I have problem starting pc after pressing acer arcade button
safemode.
1) put laptop next to you
2) press the power on button
3) keep pressing f8 repeating it fast
4) you will get a main menu
5) select "start windows normaly"
Jul 23, 2009 | Acer Aspire 5920-6727 Notebook
Black screen after Acer Arcade installed...can't find safe mode
you need to reboot then press f2 befor the computer starts because it will bring you to the option of last good configuration or like you are looking for safe mode
May 22, 2009 | Acer Aspire 5920-6727 Notebook
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
Reinstall my vista
If you want to completely start from scratch and erase all of you files to reinstall windows, here is what you have to do. You need to "boot" from the Vista CD. To do this, you will need to insert the Vista CD and then restart the PC. After it shuts down and starts to start again, will need to press the button that says "boot options" or you will need to press something along the lines of F1 (it depends on your computer type) Pressing F1 will take you to bios. From there you will need to find "boot options" or "boot priority." Set the CD drive to be on top so it boots from the CD first, before the hard drive. Then save and exit bios. This should restart your computer. After that, continue with your normal boot up until is says "press any button to boot from CD." Press any button you want to. You should be able to follow the on screen directions for installing Vista there. Hope this helps!
Apr 02, 2009 | Computers & Internet
Acer 6920g has gone onto acer arcade deluxe cinema .
I have had the same problem ... that happend to me when I press the arcade deluxe button on the blue gem controler on the left. when I tryed to run vista again it keeps going to the arcade deluxe system ...
the only solution for that case that works with me when I run the system recovery and installed fresh copy from the windows vista that came with my laptop ...
I hope that helps you in your case.
Feb 10, 2009 | Acer Aspire 5100 Notebook
in bios, locate windows vista and set it up to start automaticly , (default operating system)
Jan 13, 2009 | Acer Aspire 5920-6727 Notebook
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 laptop, cannot invoke Alt-F10 when booting initially
just press alt f10 ONLY when you see acer logo on boot and hold for a sec i had the same problem and its all adout timming hope i help...
my acer a0751h
Feb 14, 2008 | Computers & Internet
Acer Aspire 5920-6727 Notebook Logo
332 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
