Question about Mtd Garden
Won't start went to start mower yesterday turned over but would not start then it proceeded to start clicking. decided 2 yr old battery was bad and purchased a new one. put it in it still will not turn over. checked battery with meter it reads 13.56 volts so battery is good not sure what to check now whether ignition or starter?
  • l1libby1 Jun 02, 2009
    where do I check it at the starter exactly? where the positive cable bolts into it? Sorry for asking I am a woman but resourceful for the most part just want to be sure as to what to check.
  • 87 Answers
Clean connections with sandpaper until shiny and tighten all connections. Measure the voltage with one lead at the battery positive and the other at the starter (voltage drop). It must be 0.4 or less. If more, you have bad connections or a bad cable.
Posted on Jun 02, 2009
  • electricdah Jun 02, 2009
    Yes, where the cable bolts into the starter--but touch the starter part, not the cable part. That would be the bolt rather than the cable end. Also clean and tighten the negative cable at the battery and where it connects to the engine
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Why won't my Ariens 46 in 20 hp BS eng. turn over when key is turned to start?
It could be several things. First see if the safety switches work One switch should be under the seat. The second could be a bad solenoid which will not allow the current to go through the wire. Thirdly the battery connector could have a break in it. Electrical problems can be tricky to track down.
May 18, 2014 | Ariens 46 in. 20 HP Hydrostatic Riding...
1 yr old -won't start this year
probably need to clean out carby and fuel tank
Jun 11, 2013 | Toro Power Lawn Mower
2 year old Ariens tractor won't start
It could be anything from a carb issue to a spark plug or bad fuel.
May 24, 2012 | Ariens Garden
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
12.5 hp mtd starter turns slowlllllly
brush's inside the starter are bad the brush's made poor contact with the armature inside the startermotor and are not getting full contact causing the armture to get hot causing the starter not to spin at rated speed to start motor you have 2 things you can do (1) take the motor off the lawn mower unit and have it rebuilt or buy a new unit and still have the old one rebuilt so you have a spair have them test it in front of you take and place it in a dry plastic bag so you have it ready for the next time it fails
Dec 24, 2009 | Mtd Garden
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Not starting
Hi...my name is Keith..i would suspect the neutral safety switch went bad..but i dont know what kind of mower you have..it could have a bad seat safety switch or a blown fuse or the starter solenoid went bad..i hope this has helped..if not..write me back
Mar 31, 2009 | Garden
Garden Logo
108 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
