Question about Sony KP-53XBR45 53" Rear Projection Television
The red projector pulls away from the center and drops six inches
The television turns on and everything is normal for about five minutes, then the red starts to dance around and then drops about six inches down from the rest of the screen. I have tried to adjust it back up using the convergence control on the remote control but it does not move it. The red projector will stay like this for about an hour and a half, and then out of nowhere, it will pop back to normal. I cannot find a service manual online to help me figure this out, so if you could give me any type of help, I would appriciate it. Thanks!
  • 126 Answers
The convergence output IC responsible for red probably has bad solder connections on it's pins. However, resoldering it will only be a temporary fix. To repair this set properly both of the convergence output IC's need to be replaced.
Posted on Jun 02, 2009
Magnetized needs degaussing
proceed with this steps and fix it. God bless you
Instructions
    • 1 Turn on your Sony Trinitron television.
    • 2 Flip the power switch on your degausser.
    • 3 Maneuver the degausser's coil so that it is a few inches away from the face of the screen. Draw the center of the degausser coil around the entire perimeter of the screen, and then return the degausser to the middle of the screen.
    • 4 Slowly back away from the Trintron's screen. This serves to decrease the degausser's impact on the CRT's magnetic field to zero. Continue backing away until you are about five feet away from the screen
    • 5 Flip the power switch on your degausser to turn it off. The CRT's magnetic field should return to its normal state and the picture quality of your Sony Trinitron should improve.
Oct 15, 2012 | Sony KP-53HS10 TV
I just bought a used NEC Multisync MT 840 projector with just over 600 hours on the lamp counter. I live in Japan. After about 4 or five minutes of working, the projector turns itself off and won't...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. if the RPM of fan is low then the lamp can get over heated. May be its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 08, 2011 | NEC MultiSync MT840 Multimedia Projector
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Accidentally pulled the plug while cooling down. Now, when turning power on, the power indicator lamp turns to green and the lamp blinking green (normal warm-up)..but after a few minutes, the lamp...
the lamp may have overheated. check it for bulges, black spots or fogging. replace it if you have any of those. since the lamp uses vaporized mercury, the only way to test it is in another projector. it may also be the colorwheel or the fans. if all of the fans are running and the colorwheel spins up, it may be the ballast. you could send it in to a sharp service center for repair. if you chose to, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 28, 2009 | Sharp XR-11XC Multimedia Projector
Red keeps going out but there is a new bulb in place.
red light keeps blinking on and off but the tv isnt turning on
Jun 02, 2009 | Toshiba TN61X81 61" Rear Projection...
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Center speaker channel
This sounds like a bad connection inside the receiver. A 5 minute fix with a soldering iron and about 30 minutes to get to it.
If you can solder you should be able to fix this yourself.
Dan
May 23, 2008 | Yamaha Digital Sound Projector YSP-800S -...
Projector turns off
hi there may i give a shot?
fan sound get lourder......that is normal after start up
check the bulb
check the filter
restart the projector reset button back of projector
Oct 31, 2007 | Canon LV-5210 Multimedia Projector
Problem with projection Infocus 5700
the light tunnel has collapsed and part of it is blocking the image. find an infocus service center to have them fix it because they don't sell the part.
Oct 27, 2007 | InFocus ScreenPlay 5700 Multimedia...
Televison & Video Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
