Question about GE Refrigerators
Ice cube flap door
Our whirlpool side by side refrigerator is having problems with the ice cube flap door is completely loose and not sealing correctly. Same issue. Original cause was the rubber near the water spout curled and obstucted the door closing. Even with that fixed the ice trap door does not shut tight. This is causing ice/frost build up in the chute.
    Habit-Forming:
    New Friend:
  • 38 Answers
Try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Posted on Oct 22, 2017
SOURCE:
aborcass
  • 2651 Answers
SOURCE: Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Posted on Nov 20, 2008
  • 46 Answers
SOURCE: Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Posted on Jun 26, 2009
aasc
  • 1606 Answers
SOURCE: Frost inside the ice dispenser chute
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Posted on Oct 11, 2009
  • 10 Answers
SOURCE: The chute from the ice cube tray that delivers
this a kenmore made by whirlpool. u need to buy new door chute assembly. Not easy to do if you haven't worked on fridge, best to call an expert to replace it for you.
Posted on Oct 31, 2009
aasc
  • 1606 Answers
SOURCE: Frost forms on the inside opening of the chute for
The door flap which releases the ice , on the door , is not closing completely .Usually this is caused by a rusted plunger so both the solenoid and plunger will have to be replaced , These parts are located behind the dispenser board so be sure to remove the top freezer door hinge cover and unplug the plug there , to remove all power going to the door , before attempting this repair . I think the part number is WR62X10055 for the kit .
When it doesn't close , it lets warm air into the freezer and causes frost on the dispenser AND on the ice bin outlet . Also , using 10 glasses or more , of crushed ice a day can cause this .
Posted on Aug 20, 2010
I have a Whirlpool French Door Refrigerator Model #G17FVCXWY and the ice maker jams up about once a month (ice doesn't completely dump into the door bin, water refills into the ice maker, then refreezes to...
HI, we have the same problem with ours from time to time. It is a engineering flaw, bad design, the ice cubes are kept in the refrigerator section, which is about 38-40 degrees. So the ice cubes melt, the only way to keep it clear is to use ice cubes every day and not let then thaw and freeze.
Mar 11, 2011 | Whirlpool Refrigerators
Ice cube door between freezer and outside is not closing. Appears loose or disengaged from closing mechanism.
Generally, ice cubes sometimes get stuck on the flexable cover and will not close properly if they get stuck between the flap and the chute. A hair dryer blasting on the flap will dislodge them and let the mechanism close properly
Jan 10, 2011 | Whirlpool ED5HHEXT Side by Side...
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Flap on ice dispenser does not open
what make and model?-mike
Oct 27, 2008 | Refrigerators
Ice dispenser freezes up in door outlet
look at the circular flap that covers the outlet of the ice, see that it seals correctly as it closes. if there is a damage on the flap or it is not sealing tightly then frost will accumulate on the door because fresh air are coming in the door flap. if it is damage, replace the door flap. if it is stucking up, loosen up the mechanism.
Feb 18, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirpool Side by Side Ice Dispenser Freezes up
Think you have it figured out. Just had a similar problem. The flap leaked air (moisture) up into the area which then froze. Then the customer chipped it out with a knife and not only damaged the flap seal worse but also made the chute area rough from the knife tip "burrs" in the plastic chute. A new flap door with factory seal along with sanding down the burrs cured the problem. Spraying something food grade like Pam cooking spray (very lightly) will aid in the ice cube/crushed ice to slide down the chute better. With any refer, keep the moisture out or it WILL freeze up stuff.
Nov 02, 2006 | Whirlpool ED0GTKX Side by Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
