Question about Jandy AquaLink RS2/6 All Button Dual Equipment -
Jandy Time Master manual
Ive lost my Jandy Time Master manual... showing how to program the unit... this Time Maser and associated LX-10 control panel is about 20 yrs old... would you have the operations manual?
    Top Expert:
  • Jandy Master
  • 8,514 Answers
Contact jandy tech support they will walk you through it
Posted on Apr 30, 2016
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
walesarumi
  • 6993 Answers
SOURCE: My jandy wireless control panel is now blank.
unfortunately, there is no master reset button anywhere inside or on the unit.
The problem seems as if the unit is having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Jan 02, 2011
rickspool
  • 20 Answers
SOURCE: I have a Jandy Aqualink
On the RS system there is a small fuse on the back of the circuit board. That may have been burnt. It acts as a safety for the transformer. Make sure ALL of the power is off, then check that fuse. Do not keep the shorted valve actuator plugged in. Replace it, or leave it disconnected. Then replace the fuse. Then re-apply power to the unit. Otherwise your transformer may go out next. If the fuse is not burnt, which would surprise me, you may have a burnt transformer.
Posted on Apr 04, 2011
  • 31 Answers
SOURCE: My Jandy Link control panel model 8157 turns on
No. Make sure there are no programs for the spa. Double check this. I assume this is a pool/spa combination. If so, check the valve actuators at the pool equipment. Do this by manually turning on the pool with your Remote control unit. There should be no water disturbance in the spa. If so, your valve actuators need to be reset. There is a metal toggle switch on the back of each valve that you can switch to set the valves to pool or spa.
*********** board at the equipment may also be the culprit. Try resetting it by pressing the small recessed reset button on the front of the panel with the tip of a pencil or pen. If neither of these slove your problem you probably need a new mother board. They are very expensive. Check to see if yours is still under warranty. Your builder can tell you this or you can email or call Jandy with your model and serial number found on the back of the board. Good Luck
Posted on Apr 18, 2011
  • 31 Answers
SOURCE: I have Jandy AquaLinkRS4 control
No. Sounds like you have software or electronic problems. You can have those boards rebuilt for $300 hundred dollars so if you need a new one, insist your technician send it in for a rebuild rather than replace it which will cost much more!
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
What does the pressure control switch do on a Jandy lx heater?
it shows that the filter pump is working and that you have water flow through the heater
Jun 01, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do you reset an imperial hot tub flo control panel? this one is 10 yrs old.
shut it off entirely .. unplug..reconnect and power it back up reset all settings..
Nov 21, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Jandy lx 250 invalid command message
is unit on a controller if so take off remote
Jul 06, 2013 | Jandy Laars Lx 250,000 Btu Heater
LOST REMOTE BUT TRYING TO GET IT COOL...PLEASE HELP!!!!!!!...its a Haier 9000 btu model #HPRB09XC7
Stephanie, the Control Panel Operation is the same as the remote control. But, if the Control Panel is not allowing you to change the settings, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 - 20 minutes. Then plug the unit back in, turn the Master ON/OFF Switch to ON and set the controls as you would like. Hopefully, the unit's electronics reset themselves during the 15 - 20 minute timeout and you will be able to operate the unit using the control panel.
Hope this helped you solve the problem.
Jun 28, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Jandy LXI gas heater. no power to the universal controller interf
wireless system to aqualink heater must be hard wired to aqualink by either 4 pin connector or firemans switch
May 09, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
The cruise control on my 1993 Honda Accord LX, automatic 4 cylinder works sometimes and sometimes not. It worked three days ago. It wouldn't work the next day. The following day it would. Now it won't...
Sounds like possibly a safety switch associated with the brake or shifter is engaging intermittently. There is definitely one behind the brake because when you apply the brake the cruise kicks out. Try looking for this switch and check it out.
Nov 21, 2008 | 1993 Honda Accord
Jandy AquaLink RS2/6 All Button Dual Equipment -  Logo
210 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
