Question about Epson Stylus NX105 All-In-One Printer
Changing cartridge on NX105 Epson series
Changing cartridge
    Scholar:
  • 113 Answers
THE CARTRIDGES USUALLY LIVE JUST BELOW YOUR SCANNER GLASS ....LIFT THE WHOLE UNIT UP AND THERE IS THE INK....
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=116823&prodoid=63078079
HERE'S THE SITE WHERE YOU WILL FIND THE MANUAL WITH DIAGRAMS .... HAPPY PRINTING !
Posted on Jun 02, 2009
3 Suggested Answers
aicaxz
  • 511 Answers
SOURCE: my epson stylus nx105 doesn't strat right after
Check status monitor? Is the black ink recognized? Do replacement procedure on How to... Unplug the unrecognized ink tank, then plug again. If all ink tank not reach zero level ink, it must be resolved.
Posted on Oct 19, 2009
arjoy
  • 95 Answers
SOURCE: My Epson 105 doesn't recognize my Epson 88 ink cartridges
please use only recommended cartridges found either on the upper portion of your printer or in the printer manuals.... take note of the code.
Posted on Jan 28, 2010
Why to i get green lines from my printer epson stylus tx550w when I print off something
Usually due to continually using compatable cartridges. \needs a good clean then install genuine Epson. The ink jet contains about 25% of the ink. Changing a cartridge has little immediate effect on what is being printed
Feb 22, 2013 | Epson Stylus NX105 All-In-One Printer
When I try to change black cartridge in Epson NX100 the carriage will NOT STOP - flips back and forth. How do I get it to stop so I can remove the cartridge - Black is only one out.
1. Turn on your Epson Stylus NX100 Series printer. Your printer should be plugged in and connected to your computer.
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to allow you to change cartridges.
3. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
4. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
5. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer
NOTE: Beware that you must have all ink cartridges full because Epson uses color even when only printing black and white (lots of comments here about that scam!!)
Sep 05, 2011 | Epson Stylus NX105 All-In-One Printer
How to change ink on an epson stylus NX105 printer
Here is how you can change the cartridge for the Epson NX105.
1. Turn on your printer with the its support stand on the right.
2. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended. Then press the stop button again to move the cartridge back to the right side.
3. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it.
4. Now, before opening the new cartridge package, shake it four or five times to redistribute the ink evenly. Then remove from package and be careful not to touch the green chip on the cartridge.
5.
Remove only the yellow tape or sticker on the cartridge.
6. Insert the new cartridge into the holder and push it down until it clicks into place.
7. Finally, , lift the scanner slightly, release its support, and lower the scanner.
That's it!
If you need illustration, please click HERE.
Please let me know if this helps you. Thank you for using FixYa.
Nov 22, 2010 | Epson Stylus NX105 All-In-One Printer
Need all steps in changing black ink cartridge
Hi Good day!!! Here are the steps how to replace cartridges
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to show you which cartridge is low and needs to be replaced.
3. Press the stop button once more. If other cartridges need to be replaced, the printer head will indicate which ones by stopping on those cartridges each time you press stop. If no other cartridges need to be replaced, the print head will move replacement position on the right.
4. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
5. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
6. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus NX105 All-In-One Printer
Jan 28, 2010 | Epson Stylus NX105 All-In-One Printer
I have a Epson nx105 it is out of cyan ink but i have a brand new black ink cartridge in it, it wont print just black how can i print?
This is a nasty trick that many printer manufacturers pull on you. The printer may require all of the cartridges to have ink in them, even if you are only printing in B&W. As time has gone on, the cartridges have gotten smaller and smaller, and they've added these kinds of software and hardware restrictions to ensure you keep buying their pricey ink (which is where they really make their money, and why they can afford to sell the printers themselves fairly cheap).
Jan 05, 2010 | Epson Stylus NX105 All-In-One Printer
Epson nx105 has new black cartridge but cyan out. we just want to print black ink but it will not print at all b/c one is low. any suggestions?
you can change the setting in the printer prefaces or do what i did keep an empty color cartage in the color slot and a good black cartage in its slot.
Dec 29, 2009 | Epson Stylus NX105 All-In-One Printer
My epson stylus nx105 doesn't strat right after changing the black cartridge
Oct 18, 2009 | Epson Stylus NX105 All-In-One Printer
Printing
If its a colou printer change the color of your document and print.
Apr 02, 2009 | Epson Stylus NX105 All-In-One Printer
Epson Stylus NX105 All-In-One Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
