Question about Olympus FE-310 Digital Camera
Cannot get the computer to locate the camera.
After loading Olmpus Master 2 and connecting my camera to the USB I get the message that the soaftware cannot find an Olmpus camera connected to this computer.
It was a simple fix. I pushed the button on the cnera that said OK. When I did this the computer aknowledge that there was a camera attached to the computer. Thanks any way for your assistance.
--Jerry
Posted on Jun 03, 2009
    President:
  • 919 Answers
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Olympus master 2 disk does not load down from tray; needed is to install Olympus vr-310 camera disk in-order to move pictures from camera to computer file, say disk D or E; could you provide?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 05, 2012 | Cameras
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
I cant load my olmpus 300 on to pc,loaded camedia on ok but wont pick up my camera,tried to load it using devices butsays not in right file.checked usb devices,tried to add device but not having it
Consider NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jun 17, 2010 | Olympus Camedia Stylus 300 Digital Camera
Cannot load and use Olympus Master 2 on my computer.
You don't have to use the Olympus software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 12, 2009 | Olympus FE-230 Digital Camera
WHERE IS THE SERIAL NUMBER LOCATED ON FE-110 OLMPUS CAMERA
If the new computer is running Vista operating system the Olympus Master version 1.x software is not compatible.
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
Since this is a free download there is no serial number needed.
Mar 29, 2009 | Olympus FE-110 Digital Camera
Purchased a used C-3000 Zoom, 3.3 Megapixel Digital camera. Need software down load for my computer. My Windows XP program does not include this camera model.
The camera is a USB standard and serial connect camera and what we recommend for XP users as well as our new software is to look into purchasing a smartmedia card reader that connects to USB port so that you are able to transfer images using the reader as opposed to connecting camera to PC. The camera connection is not truly XP compliant.
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x and is XP and Vista compatible.
Oct 15, 2008 | Olympus Cameras
Transferring photos to PC
try using a memory card reader that supports a xd card-very generic plug and play no software to load and computer should recogtnize card-if not open my computer and you will find new drive letters for card reader in there
Jun 03, 2008 | Olympus Stylus 720 SW Digital Camera
Vista not recognising Olympus camera on USB connection
I just spoke to Olympus Tech Support.
You have to download Olympus Master 2. (Their program is no longer called Camedia Master.)
At their main site, search for olympus master 2.
Apr 02, 2008 | Olympus Camedia C-770 Digital Camera
Camera Connection
Two things:
1. The USB cable where it connects to the camera has to firmly in place otherwise it can disconnect from the computer even though it appears to be connected.
2. In the HP 635 'Set up' menu there is a section called USB configuration that has a 'computer' icon and either of these two options:
USB (Digital Camera)
USB (Disk Drive)
Set it to USB (Digital Camera). This tells your computer what sort of device is connect to it.
If you are connected correctly as above this is what happens:
1. Message: 'Establishing connection with computer'
2. Message: 'Connected to computer'.
3. images are copied to the computer.
I hope this helps.
Oct 09, 2007 | HP Photosmart 635 Digital Camera
Loading photos onto computer
Unplug all other USB devices. Restart computer then plug it in solo.
May 20, 2007 | Samsung Digimax S500 Digital Camera
Olympus FE-310 Digital Camera Logo
199 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
