Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
The cable connector running from tv is loose.
The cable connector from the tv is loose. How do you tighten it. This is the one that you run the cable from the tv to vcr. The tv is a sharp/Aquos.
  • 643 Answers
Cannot be tightend. the coax connection is soldered in place. if you use a cable box or vcr you could use composite input and get a better pict. use the vcr or cable box to bypass tvs tuner
Posted on Jun 02, 2009
Little white dots on the screen
Your cables to your TV are loose. You must have a firm fitting on the RF connector. You may also have a loose connections from the vcr to the TV [in some cases your vcr is on as well, creating these dot s you refer to.] Or loose fitting from the satellite/cable box to the TV. A firm fitting is call a good ground. You will need to check these and tighten these without breaking the connections to the tuner[RF connector]. Many of the coaxial cables you use are the slide on and are not the best to fit! Good Luck and show a few hands of support and thanks for asking!
Sep 30, 2010 | Toshiba Televison & Video
The connector was loose and eventually it came off
hi when i m opening web site n i wan to run fm news from that web site that time it was not run i want to know
Jan 21, 2010 | Vga Televison & Video
Tv rca model numberf36649 tv turns on then it
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 07, 2009 | RCA 36V430T 36" TV
Loose UHF connector
That connector is just press-fit into a metal shield around the set's tuner. It's commonly broken loose by overtightening the cable connection or tripping over the cable and yanking on it. In bad cases it can be broken completely off the set. It really doesn't "leak" anything but can cause a poor picture and allow interference to get in.
The connector can be soldered back into place with the aid of a suitable-size soldering gun. You should be able to find a TV servicer who still makes house calls. With labor and trip charge, I'd guesstimate around $100. The shop I worked for got $72 for this repair, and that was nearly 10 years ago. It is also possible for do-it-yourselfers to make this repair if they have the soldering skills. But even if you pay someone it's still less than the cost of a new set.
Jun 01, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv display says heat run
Mar 04, 2009 | Curtis-Mathis CM19011 TV
Loose steering wheel
Disconnect negative battery cable(10mm).
Insert key and rotate steering wheel until one of the mounting bolts for the airbag are visible from the backside (7/32 or 5.5 mm).Unscrew and rotate 180 degrees until the other is visible.Pry airbag off with a small screwdriver (being very careful) release yellow connector and place airbag aside with leather or vinyl pointing up.
Use a 24mm socket and tighten to 37 ft.pounds.
Reverse procedure to re-install airbag.
Connect cable and remember the computer will have to relearn its settings so car may run different for a while..
Jun 30, 2008 | 2001 Ford Focus
Tv repair
Yes, it is worth repairing. Replacing the F connector is a very simple thing, and as long as nothing was forced into the hole left by the missing F connector, the repair should run about $40.
Sep 10, 2007 | Televison & Video
Tv problem
Mine (2005 vintage) is doing the same thing. Wiggling the connector at the rear of the set cures the issue. however, it must be a loose connection inside. How about soldering the connector?
Any other ideas on how best to handle the soldering of the connector inside the set?
May 12, 2007 | Sanyo DS24425 24" TV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
199 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
