Question about Riso RZ220 Duplicator
Master wont ink up on riso 3700, How do I check ink pump and test
  • Trent G May 11, 2010
    Is this a new drum?
  • Inbar Gross May 11, 2010
    how many copies did you try to run?
  • 22 Answers
This is unlikely that the pump is not working.. I have 2 RP 3700s.. The screens are probably clogged.. with old ink.. or there could be a fit problem with the ink tube to the drum.. (no vacuum). With the drum in the machine and the ink in installed.. Take handle of a hammer and lightly (LIGHTLY!) push to ensure that there is no air pocket in the ink tube.. Carefull not to push too hard and squirt ink all over inside the machine. Also ink screens can be taken off and cleaned with varsol and re-installed.. Also as a final check.. make sure you are makeing a master.. look closely to see if you have a lazer burned image on your master.
Posted on Aug 11, 2009
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
Riso RP 3700 T12-305
t12-305 The master compression sensor does not go ON within 6.5 s after the master compression motor operates in the return direction.
kindly try to check your master roll and respool it. the problem could also be because your master cannot be dispose the old master properly. remove the old master and respool your master roll and initiate your machine or turn it of and turn it on again. hope to be of help.
Dec 27, 2013 | Riso RP 3700
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
I have a Riso RP 3700 and I changed a drum from brown ink to yellow ink and I can't get the brown ink to clear away, no matter how many sheets I run thru with yellow ink.
I've read a little about flushing drums with solvent or even gasoline or diesel google it a little see how people have done it. though I can imagine a Switch from a dark to light colour might be impossible. You could pull the screen off and wash it out. Some ideas. No solutions.
Jan 12, 2011 | Riso RZ220 Duplicator
I have the d17 error message. I did try to reset it but it still shows the error.
D17
236 - incorect master roll
237 - master roll undetected
238 - master roll communication error
239 - wrong master roll detect
241 - detected a mismatch in master roll information
you must stop the machine and remove the cable from the print drum PCB and check that there is no ink on the connector or the PCB.
If there is no ink try to enter in test mode and activate 0890 test.
If it dose not work call for tech from Riso.
Dec 01, 2010 | Riso RZ220 Duplicator
Wont print red ink
There is no master on the drum. you need to make a master.
May 25, 2010 | Riso RZ390 Duplicator
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
629 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
