Question about Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier
Keeps shutting off at the lowest volume setting.
My 800 watt sony xplode keeps shutting off at the lowest volume setting. it works but it has been doing this for a couple of weeks.what could cause this?
  • Anonymous Mar 21, 2014
    how to keep it turned off
  • 909 Answers
Check the switch wire connection. It's the one that turns the amp on when you turn the head unit on.
Posted on Jun 02, 2009
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
The power protection kicks in when I turn up my radio volume
ground wire connection or possibly amp is turned up to high when an amp is turned up all the way it starts pushin dc voltage also it could burn out the internal battery check all connections and settings after that make sure subs arent begining to blow a sub that starts to blow kicks of the amp hope this helps
May 21, 2009 | Sony Xplod 500W Bridgeable Multichannel...
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amplifier Issues
HERE is the manual for your amplifier.
It is listed as being 4ohm STEREO stable Bridged.
Meaning the lowest impedence possible on (2) bridged channels is 4 ohms.
If you have a Dual Voicecoil Subwoofer, chances are - it is wired in parallel - resulting in a 2 ohm load.
This low resistance causes rapid heat buildup, and is causing your amplifier to go into protect mode.
There are many reasons the amplifier is doing it NOW as opposed to the prior vehicle...
If you alternator is not giving your amplifier 14V, it must work harder to produce the same amount of power. WORK = HEAT!
If the head unit is not the same, the signal voltage also has an effect. If the voltage is lower, the amplifier has to work harder to keep up at the same "volume" setting.
In any case, you are over-driving the amplifier, and it is shutting down with its thermal protection circuit.
Either lower the gain on the amplifier, or purchas a mono channel amplifier made to drive subwoofers.
Your Subwoofer is craving power, and you're giving it 60W !!
Thank you for using FiXyA - A FiXyA rating is appreciated.
If you have more questions or need clarification - let me know!
Jan 21, 2009 | JVC AM FM CD DET FACE CAR STEREO
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplode 1000 watt amp
Make sure you don't have a short circuit somewhere. Make sure the wiring is all intact.
Also look at this link:
http://www.fixya.com/support/t132850-sony_xplod_1000_watt_car_amp_quit
Mike
Nov 07, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
check your ground cable and make sure it is making a good connection because sometimes this does it
Apr 19, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
My Orion 2500D amplifier turns off then back on at high volume
you need a # 4 gauge wire. check the subs conection no less than 1 ohm. check ground. and if the cap is good. 13.8 volts are for max ouput ......this is 1 ohm of charge at 13.8 volts they give 2500 watts butt only at 13.8 volts whit this relation. i¨n think you need other alternator. good look.
Feb 05, 2007 | Orion 2500D Car Audio Amplifier
Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier Logo
222 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
