Question about JBL MR-5 CD Player
Error code on JBL MARINE RADIO
What means "Error code 6" in my JBL MR-5 ?
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
  • 131 Answers
SOURCE: won't read the CD's now
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
Posted on Jun 01, 2009
SOURCE: JBL Marine MR-4
Hi I have a spa with the MR4 sterio and i want to remove it can you help as i am unable to remove it , the front comes of and i can not see how the rest comes out .
Posted on Apr 03, 2011
I have a jbl mr-145 in a hot tub. It keeps powering on and off???
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
Oct 09, 2010 | JBL Marine Audio Wired Remote
Won't read the CD's now
Jun 01, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Auxillery in question
yes you can hook up your mp3 to an aux input on a stereo not sure what you mean by converter typically it is done through a 3.5mm - 3.5mm standard audio cable. and in order to do this your reciever must have an aux input of course and if so then you can toggle the mode of input by pressing the Mode or button that switches from radio to cd etc or consult with your users manual to find out how to switch and if aux input method is supported
Feb 15, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Radio locked, code needed
you have to call jbl and give them model and serial number may charge $25
Jan 04, 2009 | JBL MR-5 CD Player
JBL MR-5 CD Player Logo
224 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
isaac johny
isaac johny
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
