From time to time my menu will come up and then the remote wont work the buttons on the front are all backwards but if i pull the speaker cover off to get to the back of the buttons and wiggle the 5 wires back there it somtimes stops the problem or i just have to unplug it and wait for awhile or somtimes days but it kinda acts like the wires are shorting out or the curcit board is bad and if thats all it is then i can replace that my self
  • a_vspecialis May 11, 2010
    Try turning off all lights including sunlight from the window before you work the remote. Flourescent lighting and CFL bulbs are known to interfere with IR remotes.
  • 126 Answers
My bet is that the MENU switch has become leaky. That's why the menu keeps coming up on it's own. If any of the front buttons are held down the remote won't work. A leaky switch is the same thing. That menu switch needs to be replaced. A real solid repair would be to change all the switches on that control panel.
Posted on Jun 02, 2009
Remote wont get fpa off
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 24, 2012 | RCA Universal Remote Control
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
Accidently pressed the FDA button on my RCA TV and now its locked and wont turn on and i dont have a remote to it
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Jun 19, 2012 | RCA Televison & Video
Tv has worked for ever with the remote now remote has failed and the on off swutch doesnt work to turn it on and off How can I program another remote if I can turn it on?
First, check to make sure the front keyboard is not locked out. Press and hold the menu key for 10 seconds then release. If it was locked out, then front panel buttons should work. If no change, you likely have a problem with one of the ten contact switches on that panel. Remove the front speaker grill by pulling it off, then trace the wires from the front control panel (you may need to remove the cover off the front of TV). Unplug the wires to the front panel and try by Remote control. If the remote works, you can purchase ten tact switches and install or just leave the wires unplugged and use it like that.
Bill W
integrityhomeworx.com
Mar 13, 2011 | Mitsubishi WS-65411 65" Rear Projection...
Wont turn on after menu pda locked,even after unpluged and pluged back in.
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Ok.
Dec 25, 2010 | RCA 32F531T 32" TV
No sound, remote locked or not working?? and i cant get the menu to work on the tv itself, the volume is stuck on 0, cant move HELP
The buttons on the front of the set fail, (like mine did) even if they never get used. Probably the 'DOWN Volume' in your case is stuck closed. Try pecking on it first. My remote stopped working but so did the manual buttons too. While poking around on stuff I swished my finger across the buttons and it all started working so I knew I was on to something. I never figured out which one was the culprit as it continued to cause problems and was replaced as a complete unit under warranty.
The other quick check/fix is to remove the trim plate around the button plate (pop out stays like the speaker covers) , then remove the button assembly (3 screws plus pop out stays like the speaker covers) then unplug the multi colored lead from the button circuit board. This puts the Remote back in control and it will work just fine like this, minus manual control of course.
Jul 19, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Some games wont register extra controllers
ress the red button inside the battery cover of the wii remote, then press the red button inside the cover at the front of the wii. do this at the wii menu to register remote 2 3 and 4
Apr 07, 2009 | Nintendo Wii Console
How do you take the front cover off. There are two screws at the
If you are talking about the front cover that contains the speaker grilles at the bottom of the unit, then there are two screws on each side of the unit. These are both at the rear of the cover on each of the sides. Undo these and remove them.
The cover is then held on by Velcro in the front centre of the panel, so you need to pull it off carefully to break the grip of the Velcro. If the TV is on the Hitachis stand then you will need to push the TV backwards off the stand by about 4 inches to give room for the cover to come off. Be carefull when moving the TV backwards off the stand that it does not topple over backwards.
Feb 02, 2009 | Hitachi 43FDX01B TV
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Discs wont register on wii system, remote wont work either
You need to sync the remote with the console.
Remove the battery cover from the remote and press the red
button until the blue lights start to blink. At the same time,
press the the red button to the front of the console.  You
can access this button by removing a small cover on the front
of the console. This will reset the machine and you should
start to see th cursor in the tv screen. Repeat this if necessary
and you should be on your way. Good luck
Sep 25, 2007 | Nintendo Wii Console
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
