Question about Coleman Mach III Air Conditioner
Ac for 5th wheel doesnt work
Ac seems to be just air circulator am i doing something wrong?!
  • steve
    steve May 11, 2010
    Probably.
Do you hear the compressor clicking or trying to run?Or just hear the fan motor?
Posted on Jun 27, 2009
Dometic rooftop ac and heat pumps not working ona 2010 heartland 5th wheel trailer will not work
check your d.c. fuses and circuit brreakers. need a full 12 volts d.c. to operate.
Feb 13, 2014 | Dometic Rooftop RV Air Conditioner
I have a neo plasma LG air conditioner, i am having problems switching on to cooling, sometimes it works, other times it is just circulating the air, making the room hot, it is 4 yrs old.
Possible problem with the thermostat which might be sensing the wrong temperature and so is not switching ON the compressor. So if the AC works once it is ON then the gas and compressor seems good. So you must check the thermostat and control board. Set the AC to a lowest temp and try.
Jan 24, 2011 | LG Heating & Cooling
Refrigerator was on AC and stopped working
some times turning them does work . / and taking them for a ride in a pick up truck . and when you get it the shop / and they tell you there nothing wrong with it . .. the ride did it .. try it / it may work. and if not then repl. **** ..
Jan 16, 2010 | Dometic RM2852 Refrigerator
5th wheel that has a plugged toilet
Put a wet vac on the hole that you open to empty the tank and tape it shut so it wont get air in then turn it on and flush the toilet sounds like something got stuck when it got to full if this don't work take stool off take it outside and turn it upside down and use a water hose to flush it out backwards from the outlet hole there may be something stuck in there that your auger cant get out.
Nov 04, 2009 | Plumbing
AC and furnace turn on and off frequently.
Your unit is short cycling. Most likely suspect is the thermostat is mounted in direct line with the discharge air. Adjust diffuser away from stat or relocate stat.
Oct 02, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Locating owners manual for 5th wheel & factory appliances
You'll probably find that the actual owners manual for the trailer is just a generic one, that covers many trailers in the fleetwood line-up. I'm guessing your worried about the AC, microwave, water heater & fridge. Get make & model numbers off them & I'll see what I can come up with. As far as items in the trailer other than that or questions, feel free to get back to me with any, and I should be able to explain most if not all. I'll also keep my eyes open at work (RV dealership) for a manual of your year.
Aug 20, 2009 | Dometic Rooftop RV Air Conditioner
I have a 1999 chevy lumina and it overheats when i am just idling and the ac is on.
This problem can be caused by a faulty cooling fan, lack of coolant circulation thru the radiator ( bad water pump, partially closed thermostat) or a partially clogged radiator. Make sure the radiator and condenser in front of the radiator are not full of dirt and clogging the air flow also.
Jul 22, 2009 | 1999 Chevrolet Lumina
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
116 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
