Question about Linksys WPSM54G Print Server
Vista 64 bit o/s will not reconize cd computer install for linksy
Linksys wireless g print server cd will not be reconized by my vista 64 bit o/s
modes wpsm54g
  • John Zupancic Jun 04, 2009
    My vista 64 bit window system will not let me install the drivers for wpsm54 G. It tell me that the o/s will not reconize the cd for installion. I already tried twince and went to linksys site to the down loads and it will not work.
    I have a new H.P. computer
    Same problem, my vista 64 bit window system will not allow me to install the drivers off the cd. The lindsys download site I have tried several time before contacting you. I have a new H.p. with all the bells and what nots.
    The computer reads not supported by o/s.
  • 10,515 Answers
This is a rare problem with Windows Vista.
Microsoft is aware of the issue and already solved this issue . Read the below technica bulletien given by microsoft :-
http://support.microsoft.com/kb/933173
I hope this would be the precise answer.
Thanks for using "Fixya".
Do rate the solution as '"Fixya" if 100% satisfied.
Posted on Jun 04, 2009
  • taran_2005
    taran_2005 Jun 04, 2009
    OOPS WRONG SOLUTION......I HAVE OFFERED YOU A SOLUTION FOR ERROR FOR VISTA CD.
    SOLUTION FOR YOUR PROBLEM :-
    FOR YOUR WIRELESS G PRINT SERVER, VISTA IS NOT COMPATIBLE.YOU NEED TO CHANGE THE O.S IN ORDER TO INSTALL CD.
    THANKS.
  • taran_2005
    Still there is one trick that might work...
    Linksys Support: Unfortunately, our WPS54G driver is not yet compatible for Windows Vista. However, we can still use the printserver by using the LPR port to add the printserver on the computer. Our only printserver that is known working with Vista is the WPSM54G. So, instead of using the driver, we can add an LPR port on your printer properties and set the port to the IP address of your printserver. Do you know the printserver IP address? Once you have the IP address, go to Printers on Vista computer and complete the following:
    1. Right click on the printer icon and click properties.
    2. Click Ports tab and make sure to uncheck the Enable bidirectional support and printing pooling.
    3. Click on add port, select Standard TCP/IP port, then click on new port (note : not new port type).
    4. Click next once prompted with the Welcome screen.
    5. Type the IP address of the print server and click next.
    6. Select Custom and click settings.
    7. Choose LPR under Protocol, type L1 on Queue Name, hit ok.
    8. Click on next. Click Finish. Click close. Click apply and then ok.
    Me: Still lists printer as "offline"
    Linksys Support: Please right click your printer icon and select Use the Printer Online.
    Thanks.
    Do rate this solution as "Fixya' if 1005 satisfied.
  • 13,433 Answers
Hey
you can download the wizard from here
http://www.linksysbycisco.com/US/en/support/WPSM54G/download
select version 1.0 from list
download the wizard file,
extract the contents of the file (right click on it and select extract all)
right click on the wizard file and select run as administrator,
the wizard will begin.
let me know how it goes.
Thanks,
Ekse
Posted on Jun 02, 2009
Computer wont reconize driver
go to bios settings and note type of cd device model number for cd drive and then search internet for windows 64 bit driver for model number and install
Jan 05, 2013 | Acer America Acer Aspire AX1800-U9002...
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
I can't install the router from the CD to my computer, I follow the steps, but when it says please wait reconizeing your router, it want reconize it says check the ethernet conections.
You don't need to install a wireless router. unplug your modem, connect the ethernet cable from your modem to the port on your router labeled internet or WAN, and then plug in the modem and router. Connect your computer to the network and you should be online.
Mar 04, 2011 | Linksys WRT160N Wireless Router
Cant get computer to reconize usb ethernet adapter. downloaded drivers from linksys site. when trying to run it says cant run sys. file
how are you installing the driver? did you extract it, if no...then extract it and the install should start automatically.
-mk3ride
Dec 28, 2010 | Linksys Compact 802.11b (WUSB12) Wireless...
Linksys Wireless G Print Server set up
Hardwire the wps54g to the router and disable all firewall installed on the compute.
Sep 07, 2009 | Linksys Wireless-G WPS54G Print Server
Unable to setup Linksys WUSB54GC wireless network adapter
The Linksys WUSB54GC isn't compatible with Windows Me, upgrade to XP or Vista. Minimum Requirements
  • 400 MHz or Faster PC
  • 128 MB of RAM Memory
  • CD-ROM Drive
  • Available USB Port
  • Compatible with Microsoft Windows XP, Vista, and Vista 64-bit edition
Apr 17, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Need working Windows 7 driver for Linksys WUSB54G V.1.0 Adapter
This driver should work with Vista, and based on the FAQ it should work with 64-bit although it wasn't designed for the 64-bit OS.
http://downloads.linksysbycisco.com/downloads/WUSB54G_dr,0.exe
If the link doesn't work, let me know. I'll direct you to the download page to retrieve the driver.
Mar 23, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Jul 07, 2008 | Linksys Wireless-G WPS54G Print Server
Linksys WPSM54G Print Server Logo
165 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
