Connect speakers what outlets at the back of the tower do I plug in the wires to the speakers ? I do not have a manual to show me. Any other speakers I've tried does not work, Please show me where to plug in my speakers.
  • Anonymous Jan 21, 2009
    I have tried my speakers (which worked earlier) in every jack available (green, blue yellow, gray) on the computer, and no sound whatsoever. I have made sure that none of the settings were muted. HELP?
    Problem Solver:
  • 6 Answers
Most of the time it's a green color jack. if not it should have a headphone by it. If you have tryed more then one set of speakers, Then try this plug the power to the speaker in to the wall and power the spearkers on turn the Volume up and tap your finger on the spearker jack it the speakers make a sound then the speakers are good if not if could be the speakers. If the speakers are good then try going to Control Panel click on Sound and Audio Devices. in the Volume tab make sure Mute is not checked and the Volume it on High. If Mute is not checked and the Volume in on high it couold be a driver. Try clicking on the Audio Tab next and make sure you sound card it selected in the frist box aka the Sound playback box most likey you sound card will have smothing to do with AC' 97. Next click on the Volume buttion and turn all the volumes all the way up see if this helps fix it. if not next we go back to Control Panel click on System click on Hardware tab then click Device Manager when it opens find a plus tabe that says Sound, video and game controllers click on the Plus sing if there's a big yellow circle with an exclamation point in it you may need to reinstall your drivers. Try clicking on the Troubleshoot frist see if it can help if not find your computer drivers on your disk or your computer maker web-site and download the drivers install them and see if this fixes your issues
Posted on Oct 24, 2007
    Scholar:
  • 90 Answers
What concerns me is that you have tried other speakers with no success... need to know what kind of computer you have?? Would also be helpfull to know if you have intergrated audio or if you have a sound card installed.
If it is intergrated audio, you usually will find three jacks in a row. Blue, Green and Pink. But sometimes they aren't colored at all.
Now if other speaker didnt work, were they "powered speakers"? Meaning, did you plug them into the wall first? Also, need to check and make sure your audio driver is installed. What windows are you running?
    Guru:
  • 1,463 Answers
On tha back of the tower they will be 3 color circuls usally the middle one saying line out plug in to there ,
riz
How do i hookup the what i think is the power cord to the computer its a round plug in
If it's a power cord, it doesn't plug into the computer; one end goes in the wall, the other into the speakers.
For most speaker pairs, there are 3 wires:
1) The wire that connects the speakers to each other. That's often fused into the back of the left speaker, and gets plugged into the right speaker (it's usually pretty well marked where to plug it in).
2) The wire that connects the right speaker to the computer. Usually it's pretty well marked where to plug this into the speaker. On the computer, that wire will fit into 2 ports. Usually those ports are marked with microphone and headphone icons. You want the headphone jack. If they aren't marked, try them both or check your manual.
3) The power cord. One end of that will plug into an electric outlet on the wall (or into an extension cord or power strip). The other end will plug into the right speaker; it should only fit into one hole (which will probably be marked with "12V" or "0.5A" or something like that).
It would help if you told us what kind of speakers you have, and what kind of wires you're seeing.
Mar 02, 2015 | Audio Players & Recorders
Tip
How to repair Computer Fan
<p>1. Remove the mini-tower computer cord and unplug the power. Disconnect the cable from the back of the computer for a note in which they were set to be fast to restore.<br /> <p><br /> <p>2. Unplug the connector on the back of the computer. Tighten the screws on the back of the computer, back up the side with a screwdriver. Slide the computer case and put it out of your way.<br /> <p><br /> <p>3. Locate the fan in the box near the back and then connect the power cord where it is on the motherboard. Unplug the fan motherboard manual. Remove the four screws holding the fan on the bottom of the box with a screwdriver to secure.<br /> <p><br /> <p>4. Remove the PC case fan and set aside. Turn the fan of the new mini-tower in the back of the cabinet with screws and plugs wire connector on the motherboard.<br /> <p><br /> <p>5. Place the rear plate side of the computer and secure it with screws. Connect the power cord to power on the back of the case and connect the cable to the computer case.<br /> <p><br /> <p>6. Connect the power cable from the mini-tower outlet and turn on the computer.<br />
on Jun 21, 2011 | Computers & Internet
Emachine w3629 pc
The green audio jack is for speaker output. If you are running the realtek audio software as part of the driver pack then you might also need to assign you speakers to the jack in the software.
Oct 31, 2017 | Computers & Internet
HOW TO INSTALL ba265
Hook your green and orange wires off the speakers into green and orange inputs on the back of your tower. Hook the round black cable off the a/c adaptor plug into the black input on the back of the right speaker. Then plug into an outlet. There is no software for these speakers.
Apr 02, 2011 | Boston Acoustics BA265 Computer Speakers
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Speakers don't work on new computer
its most likely a driver issue make sure that when they get plugged in there is some sort of conformation either on the computer or on the speakers with a light now thats you have ensured they are getting power check both ends of the speaker wire ensure neither the wire or the inputs for the wire are damaged there should be little or no play for the wire to move after being inserted . after ensuring that it not a hardware issue(to really be thorough you could hook them up to another computer and make sure after the moving process they still work) I would suggest going to the HP website and walking through they're troubleshooting mnual if still to no avail and they are under warranty just return them for new ones
Mar 30, 2010 | Polk Audio AMR50 Computer Speakers
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
Which outlet does the speaker fit in?
the socketv is there in backside of the tower
Apr 08, 2009 | HP JBL Platinum Computer Speakers
Conection
Find the Audio card of you computer. Mostly audio card jack had label line out or audio. Also audio out jack was light green in color.
Jun 17, 2008 | Boka 81000 Computer Speakers
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
379 people viewed this question
 Grubhead
Grubhead
