Question about Hitachi 53UWX10B 53" Rear Projection Television
When doing Magic Focus on Hitachi 51SWX20B I get Error 3, and the Process Stops. I have a Hitachi 60SDX88BA that also has a blue semi circle at the top of the screen. I have run magic focus and it stops and flashes a 3 in the bottom right corner. Has anyone found a fix for this? Hitachi's customer service response was less than helpful.
  • Hitachi Master
  • 3,459 Answers
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a commonWhen doing Magic Focus on - 0667c5f.pngbr />
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 20, 2009
    Scholar:
  • 150 Answers
Your convergence ic`s have failed and the set is telling you by showing the error codes on the screen, either 2 or 3 stk chips and possibly a few burnt resistors will have to be replaced, only you know if you can handle this type of job, requires soldering & un-soldering equipment, service info, heat sink transfer and oem stk`s do not buy the elcheapo 9.99 ic`s from the internet, they do not hold up,if u need more info ask away, video-tek
Posted on Jun 05, 2009
Shaded color tinting everything in pink and green. I've tried Magic Focus (5). It's a Hitachi 51SWX20B.
sound like a common problem where the coolant for the tubes has become contaminated. It is possible to replace the coolant yourself and can be a much cheaper alternative to getting repair shop to fix.
do a search for replace coolant 51swx20b
Oct 21, 2013 | Hitachi 51SWX20B 51" Rear Projection...
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Mar 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 51-SWX20B Out of focus...tried magic focus and it stops on red. Tried manual focus but red lines won't move. How expensive is this going to be to fix. It is 7 years old and need to know if I...
YOU HAVE A CONVERGENCE PROBLEM. THE RED OUTPUT IS OUT. COMMONLY IT HAS BEEN FOUND TO BE THE DIGITAL CONTROLLER MODULE THET CAUSES THIS BUT THE OUTPUT IC SHOULD BE CHECKED FIRST
Dec 26, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Have an Hitachi 51swx20b. The colors are not aligned and magic focus will not work. Vertical and sharpness is grayed out...
Ur convergence it dead.U know how to solders?Buy a convergence kit to replaced parts.Websites Tv repair World.com Tvrepairkits.com.
Dec 16, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
Green is way out of alignment
Need to have convergence board rebuilt, do not adjust anything this will make the technician charge more for the additional labor of having to "undo" your "repair" leave it for a professional technician, as it can be dangerous. we would charge at least $400 this would include readjustment. Millenium Tv - milleniumtvsvc@gmail.com
Jul 21, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
450 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
