Question about HP PSC 1315 All-In-One InkJet Printer
Hp1500 color laser keeps printing test page only
My printer HP psc 1355 all in one has an error on all the time and it says check ink cartridges,Any idea??
Posted on Nov 13, 2007
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Vertical lines
Lines in prints with this machine would suggest a fault with a drum unit. As each toner cartridge contains its own drum unit it is likely to be a particular colour at fault. If the colour is not immediately obvious, I would recommend printing off a test page like the one here:
http://www.refreshcartridges.co.uk/igloo/colour-laser-printer-test-page/
Nov 19, 2012 | Canon Imageclass Mf-8350cdn Color Laser...
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
What are the starting instructions?
I believe you can download the operators manual from HP's website.
Jul 30, 2009 | Office Equipment & Supplies
How do you print a test sheet on a dell 5100 cn of the various colors?
You can see the colors printed on this printer in three different methods. Well, there may be more, but I'll discuss three.
First, there is a menu screen on the printer. you can choose to print a test page from this menu. It should print in all the available colors.
Second, you can open the printers folder on your computer. Find this specific printer and look at its properties (right click, properties). Under the General tab, found in the lower right corner, there is a button to print a test page. This test page is a WINDOWS test page, and will display come of the colors on the Windows logo.
Third, you can open your favorite picture, whether it is one you took with your camera or a sample picture in the operating system. Click File, Print, and be sure the Dell printer is selected.
Good luck.
tony
Jun 10, 2009 | Dell 5110cn Laser Printer
Xerox 7700 intermittant banding on a diagonal black only
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Sep 07, 2008 | Xerox Phaser 7700 Laser Printer
HP1500 Alignment Test page keeps printing
I just had the same problem on a PSC1350 after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Dec 10, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
HP PSC 1315 All-In-One InkJet Printer Logo
194 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
