Question about Maytag MDE2600 Electric Dryer
Electric dryer won't start
My Maytag Preforma electric dryer won't start could it be a thermostat or controller My maytag dryer won't start at all. How can I troubleshoot it?
  • 6,784 Answers
HI, check the following to address this issue you are experiencing.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 02, 2009
2 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: electric dryer won't start
Check the breakers, then the wiring from the receptacle, the plug and then the wiring to the back of the dryer. If not there, then take the top off and look for the thermal fuse. Bypass it and see if it comes on. If so, replace it and you should be on your way.
Posted on Feb 03, 2009
Maytag elec dryer no start
i choose that because its meant for that purpose,of fast and easy tap controls and serving.producing great results.
Apr 01, 2012 | Maytag SDE4606A Electric Dryer
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
MAYTAG BRAVOS DRYER CODES FLO, CO WON'T START AFTER STORM
I have the same problem. Technician recommended to replace main control board - didn't help. Now I ordered the user interface board. The self test results in C0 code which stays till reset.
Jul 04, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
How do you change the air flow from the back to the side? maytag preforma
inspect the dryer sides,and see if there is a knockout to remov to allow side venting,some dryers are not side ventable,if the knockouts are there, you may need a kit from maytag specifically for that model...the installation instructions may be helpful if you have them,could provide kit no.,and the how to instruct.
Mar 06, 2010 | Dryers
Feb 03, 2009 | Maytag Dryers
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
Feb 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer Tstat wiring
I believe that this part is a thermostat. If im not mistaken, it shouldnt matter which wire goes on which prong. Think this is a reversable thermostat. It should have just 2 prongs correct? Jim
Aug 31, 2006 | Maytag PYE2300AY Electric Dryer
Maytag MDE2600 Electric Dryer Logo
235 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
