Xantrex Technology Heart Freedom 20 12 Inverter Logo
Posted on Jun 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power coming into inverter, nothing going out. Batteries will not keep charged. Also have solar panels that should keep power, are not. 1994 ****** Patriot.
Ibe Chukwudi
Level 2:
Guru:
  • Expert 290 Answers
  • Posted on Feb 27, 2010
Ibe Chukwudi
Expert
Level 2:
Guru:
Answers
290
Questions
0
Helped
80814
Points
599
It is possible the cont actor or relay that do the switching is bad
Can a sunny boy inverter work with a 10kv Generator?
First I assume that you thinking about kVa not KV? or you really have 10000 Volts generator?
why would you like to add inverter? Considering your setup there is no need for inverter.
the only way you need inverter is when you have dedicated battery bank. This way system would work this way. On sunny day you produce electricity to feed your house and charge battery bank using charger/inverter. Once solar panels atop producing electricity during night system automatically switches to inverter mode and you start using power from batteries. Once batteries goes low then generator kicks in and supply power to home and recharge batteries. Without dedicated batteries there is no use for inverter
Will my 18watt solar panel charge a car battery and how fast?
If you hook it up correctly and the Voltages match... yes.
As for how long... THAT depends on a number of Factors... How much sun, What quality is the Solar Panel, Placement of the Panel.. the goes on and on... But you CAN charge a Battery...I charged a Battery for quite some time using a Large Solar array.... We were Camping an using the Battery for Lights Radio and Fridges.... So it CAN be done
2answers
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
1helpful
4answers
How do i convert my 1.2kw solar inverter on my roof so i can run my home on stored energy ?
Solar panels produce DC voltage.
some solar panels have the inverter integrated into each solar panel.
I would suggest contacting a local solar panel supplier and asking them if they could add a Battery Charging System to the Solar panels you use. An then what sort of inverter to add to the bank of batteries.
An inverter converts DC voltage to AC voltage to use in the grid.
The AC voltages and DC voltages involved have the possiblity to kill if you much around with electricity.
2answers
SunForce 2500w pure sine wave converter add on
Mixing different AH rated batteries, different ages of even the same type battery is a bad idea. The new batteries will be effectively reduced to the equivalent of your worst battery.
2answers
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Tatronic inverter problem
Tightened up battery connections
1helpful
5answers
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Top Xantrex Technology Boating Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
