Question about Microsoft Windows XP Home Edition
Cannot find operating system when booting
During boot the operating system cannot be found, I tried to enter safe mode, but will not let me, tried reinstalling xp, but will not accept even though i am booting from c/d, tried boot disk but will not let me change boot sequence, I already replace the c-mos battery, Im totally lost now.
Have gigabite motherboard, seagate harddrive, nvidia 9600 GT graphics card, 10/100/1000 lan card, 500watt power supply, lite-on dvd, memorex dvd, am running 5 fans
  • ws747 Jun 03, 2009
    Tried all connection still no luck, how do I lessen my fan usage, do I disconnect them, boot disk ,usb disconnected
  • 700 Answers
Could be your harddrive is out of the system. Check its connections first, then have it detected. If not still been detected try changing cables and power plugging(interchange if it can). Other done than maybe failed drive already.
And before I forgot remove any other booting disc, usb, or flash card. Maybe you left one. Or try to lessen your fan usage during fault finding.
Posted on Jun 02, 2009
  • fougzki Jun 03, 2009
    Clarification, could you boot in cdrom first? Can you get to DOS or command prompt?
    Ok if you can, then try to access the hard drive. If you can acces it in dos prompt say c:\, then chances are you have corrupted files. Try first to boot using your installer cd then wait until you have the options in REPAIR. If this doesn't work, then use Partition Magic if you can have a rescue type cd much better, use the appropriate version for your hard drive capacity. But this process is actually near to formating the drive itself.
    Other procedure is to use another blank formatted hard drive into the system.
    For the easiest way if you don't have an spare then have it check by a qualified tech, you will not gonna worry for the spare for the test.
How do I turn off safe mode windows 7
If you're saying it always boots into safe mode, try pressing Windows key + R, then type MSCONFIG and hit Enter. MSCONFIG screen will appear. Go to Boot tab and see if Safe Boot is checked. If yes, uncheck and click OK.
Sep 07, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I cant remove or add programs because my dell 6000 laptop is in safe mode an i dont know how to get it out of safe mode
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Jan 20, 2013 | Computers & Internet
Attempting to install OSX on WD7500BPVT Hardrive. OSX says HDD is locked.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
if its password protected (locked)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 14, 2013 | Western Digital 750 GB Scorpio Blue SATA...
Please help me with problem starting up windows because of forgotten password
The password first.
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Now if you want to reinstall or load another operating system.
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
Hope this helps.
Dec 22, 2012 | Computers & Internet
How to put toshiba f20 into safe mode
when the computer first starts to boot up tap the f8 key this should bring up the options for booting into safe mode if not try f5.
May 02, 2011 | Computers & Internet
During installation of Windows XP, the computer crashed and now it can not be restarted. What can we do?
try restarting it and go into recovery mode. if you cant get it to do that then try reinstalling windows xp. if you have a disk and still cant get it to install then the disk might be bad.
Jan 16, 2011 | Computers & Internet
My dell inspiron will not boot it says no bootable device found
Hi, try pressing the ESC key during bootup, this will allow you to boot in safe mode, from where you can reset your operating system to a time before the problem started.
If this dosn't help come back to me for help on re installing operating system.
Aug 01, 2010 | Dell Inspiron 1525 Laptop
Lenovo 300- N200 fails during the boot process. Screen freezes after boot sequence.
Is it working with latest update from windows if you are using any windows operating system? Some applications installed by you which run at startup time hug the system.
You can try logging into the system in safe mode and try to see whether you are able to enter into the system or not. Once entered with safe mode rename the installation folder for the new applications that you might have installed, after which the system started freezing.
After renaming it you can boot the system in normal mode. As the new applicaiton will not be able to run (due to folder renaming) it is most likely that the system will boot properly and you will be able to enter the system.
Then rename back the folder to original verify the compatibility of th eapplicaiton and if possible uninstall the application.
This process has saved me from a lot of system complications. Hope this helps you.
By the way which operating system are you using?
Nov 08, 2009 | Lenovo 3000 N200 Notebook
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Operating system
This will be either an operating system glitch of a failed hard drive. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive will not format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Sep 03, 2008 | Sony VAIO VGN-S460 Notebook
Microsoft Windows XP Home Edition Logo
425 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
