Home | Motorola | GP300 Compatible 2 Way Radio Battery Eli... | GP300 frequency pro...
Motorola GP300 Compatible 2 Way Radio Battery Eliminator
Problem for Motorola GP300 Compatible 2 Way Radio Battery Eliminator
GP300 frequency programing
By djmatt677 on Jun 02, 2009
I have 4 Motorola GP300 radius on UHF using 456 to 462 Mz. I have just got 2 more but the frequencies do not match mine and would like to program them myself as I am looking to add 4 or 6 more. I only use them back to back and dont need anything fancy although a scanning channel would be useful I can get a RIB programmer but what else do I need? PC ? what spec. I understand it needs to be done in DOS at a slow speed ? do I need a program and can I get this? as I would realy like to do this myself DJ Midlands
Solution #1
posted on Jun 02, 2009
Not Rated)
eradiostore
Rank: Guru
Rating: 91%, 293 votes
Here is what you would need: RIB (radio interface box), HKN9857 programming cable and HVN9128 programming software. You are correct the software is only capable of running on a DOS box, such as a 286 or 386. The software mentioned is Motorola proprietary and is available to Authorized Motorola dealers by subscription only.
The book also shows a cloning cable HKN9755 as being available. Don't know anymore details on it.
Lastly, the cost of programming to your FCC assigned frequencies would be approx. $15 per radio, and less for cloning like models. It might be less expensive to have the radio programmed by a dealer. Just an FYI.
Best regards
Was this helpful?
Yes
No
Popular Solutions for Motorola GP300 Compatible 2
Questions and Unsolved Problems for Motorola GP300 Compatible 2
Do you recommend Motorola GP300 Compatible 2 Way Radio Battery Eliminator?
Answer
Answer
cordless phones have static
Answer
I am looking for at least some minimal information on the motorola systel L1796A as far as technical... (More)
Answer
I have a motorola ht600e on the frequency of 446.??? I find that they are not very sensitive, as my... (More)
Answer
I need a manual for a pair GMRS 1582 CH fm transceivers. I got them second hand and have been... (More)
Answer
yeasu mark 5 field putting out 20 watts on 10,15,20,40 and 160 mtrs 100 wattson 80mtrs
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motorola GP300 Compatible 2...:
Top 2 Way Radio Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more 2 Way Radio Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
