Question about Logitech ClearChat Pro USB Headset
Wiring schematic for a wired Logitech Stereo Pc headset
Please I'm trying to adapt a logitech wird PC headset (ear + mic) but I don,T have the wiring schematic neither the impedance of the microphone as the earpieces. Please Help me ! Regards Ben somebody should semi-mutilate their logitech headset so the world can know what color wires go to data and what color go to power.
  • chrispretti Jun 30, 2009
    If you do decide to try fixing it without schematics.. beware.
    i called logitech tech support, they didnt know anything about the wiring. I was trying all the wires and i would hear the speakers sometimes, then i gave up and took a shower and when i got out, my usb ports were fried. my mouse and keyboard wouldnt work although the headset had been unplugged while i was in the shower and the peripherals worked fine before i took the shower.
SOURCE: My Ps3 Headset -- LOGITECH
This sort of happened to mine, but i just switched my headset output to the default, so it comes out my telly instead of the ear piece...
Hope this helps
Posted on May 27, 2008
SOURCE: Logitech 350 Headset Casing
Had the same problem, no headphone speakers would work.
First use a flat head screwdriver and insert in between leather padding
and plastic case and pry apart. Best to start at one area, insert a wedge
and pry further along. It will take a bit of force before it pops apart.
Take out 4 small philips screws
I found that the wire had broke right at the entry grommet. I pulled the
wire through and wiggled it and the speakers went on and off.
In my case I felt it was best to redo all the wiring. I first took these pictures
to have a map and pulled through an extra 4" of wire through and cut/desoldered
the wires.
Here are the original wiring connections at the speaker
4017e98.jpg and what must be the common. This was the wire that was broken
inside.
I re-soldered all the connections and separated them as best I could with
electrical tape (no shrink). Put everything back together and so far
seems to work fine.
Posted on Dec 23, 2008
SOURCE: hi, I just purchased a
I've found that it works to go into the Control Panel in the classic view, and under the Speech Recognition section to configure the headset.
Posted on Jul 31, 2009
  • 14 Answers
SOURCE: I have a short wiring in my left ear cup
Time for a new pair. If you are not handy with a sodering iron it is best to buy another set. Once the wires are broken inside the insulation the only thing that can be done is replace the wire itself. it is easy to break the wires inside the insulation twisting the cord, pulling or yanking the cord, along with blending the cord in a sharp bend acn damage this cords that they put on products today.
Posted on Sep 12, 2009
Crenshow
  • 250 Answers
SOURCE: logitec250headset mic not working at all on this pc
Hi, Please uninstall any logitech software version present on your OS - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Posted on Jun 09, 2010
Left channel no sound on logitech headset
Usually something like this is simply the wire at the headseat becoming broken by twisting and stress. If you gently twist and push right where the wire enters the ear cup. It will work and then stop as the wire make a connection. Unless you can solder you will end up replacing the set. Make sure to try it out on a different pc or mp3 player etc just to make sure it is the headset.
Sep 10, 2012 | Logitech Audio Players & Recorders
Logitech h250 mic not working
I've checked the mic settings, and adjusted them fully up. When I test them as hardware, they work, when I play a game, they don't work. Very frustrating.
Jun 06, 2012 | Logitech 250 Headset
I got new Logitech Clearchat stereo headphones. I plugged the two pins into the pc - pink and green. When I do a skype test I hear the message from my computer speakers (settings says Realtek HD..with no...
realtech hd is your sound device. go into windows control panel and access the sound settings then navigate to voice settings click the volume button,your mic might be muted. also if you want the headphones to work plug them into the plug that your speakers are using (side-note: mics and head phones never need something installed to work as long as your sound device works and your definitely does work,only when the mic is a special interface like USB do you need to install software and/or drivers)
Apr 01, 2011 | Logitech ClearChat Stereo Headset Headset
The Microphone for my logitech headset (clear chat) will not work with Skype.
Try checking if the mic volume on the pc is enabled, and if it's pointed to logitech.
Jun 06, 2010 | Logitech ClearChat Stereo Headset Headset
I have a short wiring in my left ear cup of my Logitech Wireless PRO USB Headset, and sound out of that ear shorts out all the time.
Sep 12, 2009 | Logitech Clearchat PC Wireless Headset
Logitech clearchat stereo won't work on my inspiron 1545...
try uninstalling sound card from the device manager and reboot the computer.
if the mic does not return you may be missing a driver contact your laptop manufacturer or download new sound card drivers from the websight to restore mic function.
Jul 02, 2009 | Logitech ClearChat Stereo Headset Headset
Clearchat Stereo Headset's mic not working.
go to device manager and check for enumeration under the sound,video and game controllers. if the headset is listed it should work. if not or there is an unknown device. try on another pc. if the same happens call logitech.
Jun 01, 2009 | Logitech ClearChat Stereo Headset Headset
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Logitech premium usb headset 350 help me pretty please
If when you talk into your mic you hear yourself from speakers...open your volume control(windows) and check the box to mute mic. Not for sure this is a fix to your problem but from what you wrote is similar to problem seen with voice chat software.
Feb 16, 2009 | Video Game Consoles & Games
Mic doesnt work
have you tried looking in your multiplayer option ins FSX to make sure you have the correct input selected?
Aug 29, 2008 | Logitech Precision PC Gaming Open Air...
Logitech ClearChat Pro USB Headset Logo
2,185 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
