Question about Hitachi 50UX57B 50" Rear Projection Television
Dirty screen but it is behind the outside screen.
How do you clean the spider webs out from behind the screen? On my hitachi 50 inch projection tv. how do you access the screen area to clean behind the front tv screen, I can see spider webs in the picture?
  • 06will Nov 28, 2007
    i have a dlp mitsubish w-52527 and i have spider webs behind the screen so how do i get them out?
I have the same problem. I can see spider webs behind the screen and would like to know how to clean it myself without a technician. Please help me understand how to do this myself.
Thank you,
Posted on Dec 07, 2008
    An expert whose answer gotĀ voted for 100 times.
  • 140 Answers
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Posted on Oct 24, 2007
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
How do i clean the inside of my 57" projection tv . this is an hitachi flat screen, i have spider webs inside
without knowing the model number; some you can remove the rear cover and gain access with a swiffer type duster and clean the webs out(also clean the lens at the same time) Others: the only easy way is to remove the screen--not real easy if you have never done it before---most outside service techs will be happy to come to your home and clean the webs out; also clean the lens and the mirror.
Aug 06, 2009 | Hitachi Televison & Video
I have a spider web behind the screen, how do i
sometimes on sony TV's on the sides you will have a door, that you can open with a screwdriver. if yours have it you might be able to dlean all that web from both sides, if not its a little bit more complex.
Jun 25, 2009 | Sony KP-53HS30 53" Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Inside the cabinet projected on the screen?
well . there are 4 things that can cause this..
1= the outer screens could be dirty.clean with screen protector cleaner.Spray on cloth and not on outer screens.
2= outside lenses of picture tubes could be dirty.Unit can be opened .Outside lenses can be cleaned with a lens cloth .Do not use paper towels or cotton as this my scratch surfaces of lenses.
3= inside of picture tubes could be dirty.This should be done by a repair shop only(dirty coolant inside tubes)
Dec 28, 2007 | Philips 55PP9401 55" Rear Projection...
Hitachi 50
Yes spider look inside, goto and email for answer.
Dec 22, 2007 | RCA R52WM24 52" HDTV Projection Television
Spiderwebs under Screen, how do i clean it ?
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Jun 24, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Trying To Remove Screen
I have a panasonic 53 inch and have had the same problem on numerous occasions. I removed the backing of the television, stuck my vaccuum cleaner hose inside the tv and sucked out the spider and the web.
Apr 29, 2007 | Toshiba 65H81 65" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
293 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
