Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor wont drive or engage electric clutch.
HElp! I have a sears Model# 917272960 garden tractor with hydrostat drive. starts and runs strong until i put it in drive or pull switch to engage the electric clutch then engine shuts down.
  • Anonymous Mar 16, 2014
    tractor will start and run with the choke on but when I take it off of choke it bogs down and shuts off
    Novelist:
  • 153 Answers
It thinks you aren't sitting on the seat.
There are 2 wires and a switch under the seat. The plug may have come off, the connections might be bad, or the switch might be bad.
Posted on Jun 02, 2009
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
What is the Function of the pto control
It is to supply power the electric clutch that drives the mower deck.
If not functioning then the switch, PTO clutch, or wiring is not working properly. Note on some ZTRs when both handles are in reverse then electric clutch is disengage for safety.
Oct 06, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Disengage mulch drive
Have you looked beneath the deck with someone engaging or disengaging the blade lever? Get underneath and observe how the belt travels from the engine pulley back, and follow it in the loop it travels to see how it works with the lever engaged and disengaged.
Jun 08, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
MOWER WILL NOT ENGAGE
check the fuse then see if theres power to the clutch is there a bad safety switch does the mower shut off if you get off the seat when the blades are turned on(that will test one of the safety switches)
May 04, 2012 | Husqvarna LGT25K54 Garden Tractor
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
GTH2548 drive spring broke and I replaced it. Tractor would not start. Replaced battery, start switch, seat switch and PTO switch. Tractor will now start and runs well. However, when PTO switch is...
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Sep 08, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
I have a 17hp Hydrostatic Garden Tractor, slow
You will find some pretty savvy guys at MyTractorForum.com. They will help you.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Not sure, but i think the electronic clutch is not engaging when i push the control levers forward or backwards. the engine and the mower deck both run, but the mower will not move
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
Nov 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
Oct 19, 2009 | Craftsman Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
385 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
