Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Inside water dispenser does not work. i press the button or the pressure bottom but it still does not work. we changed the filter to no avail. how can i get this fixed? thanks annette
  • 868 Answers
Check for power at the water valve .You probably need to change the valve.
Posted on Jun 03, 2009
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Tip
How to Reset Your Water Filter Light
<b>Amana:<br /></b> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>auto light</b> buttons on the dispenser for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>After replacing the water filter, press and hold the Reset Filter pad for 3 seconds. The Order and Replace indicator lights will blink and then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br /> <ol> <li>Press firmly and hold start button for 5 to 10 seconds.</li> <li>Four bars will appear in the display, one after the other, and flash. Do not release the start button until the 4 bars appear and start to flash. If you have difficulty pressing the start button, a capped ballpoint pen may be used to press the button down.</li> <li>A small flashing dot in the lower right corner shows the indicator is working.</li> <li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li> <li>After 2 months, when all bars have disappeared, an arrow will flash at the top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b> <ol> <li>Press and hold the <b>reset </b>button on the dispenser until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol>or<br /> <ol> <li> Press the reset button on the dispenser for 4 to 8 seconds then release. </li></ol><b>Hotpoint:<br /> </b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol> <b>Jenn-Air:<br /> </b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b> <ol> <li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br /> </b> <ol> <li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b> <br /> <ol> <li> Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol> <b>Maytag:<br /></b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br /> <ol> <li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br /> </b> <ol> <li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li> <li>Release the buttons and repeat the same step one more time. The water filter indicator light should turn green.</li></ol>or<br /> <ol> <li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br /> <ol> <li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i> buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol>
on Jun 17, 2011 | Refrigerators
The inside water spout on this refrigerator stopped dispensing water
Checckwater pressure.The 1/4" water supply line should deliver at least 9 ounces of water in 5 seconds. If not, the water pressure is low. Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced. Thanks.
Feb 03, 2011 | Amana ARB2259CS Bottom Freezer...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
Jenn Air fridge water dispensor stopped working
Hi: You press the switch and it makes a faint humming noise. That tells me the switch on the front panel is ok. The switch for the ice and water is actually on the bottom of the ref. The internal system of the ref is not under city water pressure. Ice is made so that's ok. There is a solenoid where the water attaches to the fridge down below which can fail. Just for giggles try tapping the switch with the plastic handle of a screwdriver. To loosen any scale that might have built up. As I'm unemployed also I'm giving you that trick. Otherwise I would just say replace it. I hope this helps, Jeff
Jun 09, 2009 | Jenn-Air JBR2088HES Stainless Steel Bottom...
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Aug 15, 2008 | KitchenAid Architect KBRA20ERSS Bottom...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Interior Water dispenser not working
if you have not yet used it you will need to bleed the air out of the tank in the refrigerator hold the button in for a few mins to flush this out
Jan 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
