Question about Roper RT18VKXKQ / RT18VKXKZ Top Freezer Refrigerator
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
There is water collecting in the bottom of the "fridge" and in the vegetable bins. We have taken the "floor" out of the freezer compartment and melted the ice that formed there once when this happened and it seemed to solve the problem at the time. However, the problem has returned. What should we be doing. Problem with bottom of refrigerator getting water pooling in it and freezing. This is a Roper refrigerator with top freezer, that is about 8 - 10 years old. Problem has just started within the past couple of weeks. The water is dripping down the back of the refrigerator from the freezer and gathering at the bottom of the fridge under the drawers, and eventually icing.
  • 954 Answers
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Posted on Apr 01, 2017
  • 198 Answers
SOURCE: water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Posted on Jan 27, 2009
  • 103 Answers
SOURCE: Water in bottom of "fridge" and in vegetable bins
Hi: I'll assume this is should be a frost free freezer. If so the defrost drain is clogged and the water isn't getting to the evaporator pan. Without knowing the specifics although it sounds like a top freezer. Look for a drain below the evaporator coils. The will be in the back of the freezer behind a panel. Some models have a drain hose behind the ref. Use a strong solution of clorox and water to clean it out. The parts list or diagram of the fridge will help you find the drain. If you don't have it enter your model no. at sears.com parts direct. I hope this helps, Jeff
Posted on Jun 03, 2009
Maytag317
  • 1136 Answers
SOURCE: Water is dripping from the freezer into the refrigerator
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 11, 2009
woodchuck789
  • 4070 Answers
SOURCE: Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
aasc
  • 1606 Answers
SOURCE: My Roper refrigerator collects water in both
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Jan 22, 2010
Testimonial: "Wow, even I can fix my fridge!! Thanks for the excellent advice."
Water Leaking from Freezer Side of Refrigerator
Got a couple of questions before we can really say much Does the refrigerator/freezer appear to be running as normal? is it perhaps always running at the time the water leaks for longer or more noisily than normal. Is the temperature of the freezer as normal? is there a particularly cold patch in the refrigerator , probably at the back or on the freezer side near the bottom? Where exactly is the water leaking from? and is there water collecting inside? Does the door seal properly at the base where the water seems to be coming from? Is there another major appliance with a heavy current draw that always goes on at the same sort of time? I'm thinking a water boiler, or aircon/heater, or the oven etc. Please post back, and we can start running through possible solutions :)
Jun 28, 2007 | Jenn-Air JCD2389G Side by Side...
Ice is forming in the bottom of the freezer compartment of my hotpoint FFM90 frost free fridge/ freezer. Please help. Many Thanks
Had exactly the same problem.
It was due to a blockage of the drain.
At the back of the freezer there is the pump and there is a small darin that lets condensation from inside the freezer spill onto the top of the (hot) pump to be evaporated. When this small drain blocks it causes issues like water leaking out of freezer and big chunks of ice at the back of the bottom compartment.
The fix is easy, if a little laborious.
Take all the stuff out of the freezer, then dismantle the internal plastic trip, don't worry, you can't really break anything and it goes back together easily, Eventually you will be left with just the bare metal insides and in the middle at the bottom back you will see the drain collection point, slightly hidden from view is the drain hole. Pour warm water onto this till it comes out onto the pump at the back.
Then use a pipe cleaner to clean.
Re-assemble - done :)
Oct 15, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
I have a Frigidaire Side-By-Side refrigerator Model #FRS26ZSHB3, that is collecting water on the bottom of the interior of the freezer side. I have to remove the ice every 2-days, otherwise the water leaks...
Drain system is clogged.
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
Jul 15, 2010 | Frigidaire FRS266ZDSB Side by Side...
Water will not dispense--fairly new filter
Are you sure about that model number because I have the service manual for a RS265AA if you like. The water valve can be tested ao back with a multi-meter and should show 120 volts or your home voltage when someone presses the dispense water switch. If yes the voltage is present the water control valve is defective and will need replaced.Double check your model number because there are no Samsung refrigerators with the RF2 prefix RS2 is Samsung prefix. Let me know, what you find, Sea Breeze
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Water pooling and freezing in bottom of freezer. I've shut the valve so no water is going to the ice maker but water still collects. I can't figure where the water is coming from. Can you help? Thanks!
Sounds like the drain from the freezer evaporator coil is plugged causing the condensate to overflow and fill the bottom of the freezer then refreeze. Most freezers have a drain line from the evaporator to the bottom of the refrigerator leading to a collection pan to allow evaporation of the condensate. You may be able to access the evap condensate pan by removing the rear panel of the freezer. I can not say for sure without the specific model of the unit in question.
Jun 23, 2009 | LG LFC25760 French Door Refrigerator
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | Refrigerators
Roper RT18VKXKQ / RT18VKXKZ Top Freezer Refrigerator Logo
88 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
