Question about Akai LCT3201TD 32 in. LCD Television
Trying to get DTV, I can't figure it out
I don't have cable, I want to see the playoffs. Rabbit ears worked last year. This year it's wacked. Manual might as well be in Chinese.
  • 696 Answers
If you are in the US you need a digital reciever, rabbit ears or otherwise and have since February. That when all US broadcasters switched to digital broadcast. If it's more than about 5 years old you will likely have to purchase a new TV.
Posted on Jun 02, 2009
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
I have a 13 inch TV with a small table top antenna with rabbit ears on it and a dial. I plugged the antenna cable into the converter for antenna in. I plugged a cable from converter box to my TV. I was...
You may need an antenna that gets VHF and UHF bands. The "rabbit ear" antenna is designed for VHF band. Many of the DTV channels are located in the UHF band. You may want to call the FCC's DTV hotline for help. They will know the TV stations in your area and can tell you if you need a different antenna. The can also arrange for someone to come help set up your DTV converter at no charge to you. 1-888-CALL-FCC is the number.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Analog or dtv
Hi, This tv has an NSTC tuner which is analog. If you subscribe to cable or satellite it will work just fine without you having to do anything for the upcoming change. However if you are using your own outside antenna or rabbit ears you will need a converter. Hope this helps.
Jan 30, 2009 | Philips 20PT6446 20" TV
Can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Jan 28, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Jun 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
No HD
Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
Mar 15, 2008 | Protron PLTV-4250 42 in. LCD Television
Akai LCT3201TD 32 in. LCD Television Logo
82 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
