Question about Dell Vostro 1500 Notebook
No output at all
Dell vostro laptop went off. Started up again and went into repair mode because windows was not shut down properly. Completed repair and went off again shortly afterwards. Started up again and attempted repair process - this happened a couple of times. Now it will not start at all
    Problem Solver:
  • 17 Answers
Okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Posted on Jun 02, 2009
  • Ssubash Apr 25, 2011
    hi i try the above options it doesn't helped me
My dell vostro 1015 gets completely shut down without giving any prior warning..i have to restart it again and it shows that windows didnot shut down properly.it happens 3 to 4 times a day.plz help..
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Dec 02, 2011 | Dell Vostro 1015 Laptop
Long time shut down problem of laptop dell vostro 1015 with core 2duo
What is the exact problem.
A Does it turn off automatically after few minutes Or
B It fails to shut down when you choose to do so ??
If the system turn off automatically, try to clean the cooling vents and make sure that the system is not overheating
If the system fails to shutdown, test the system in safe mode. Restart and tap F8 repeatedly, select safe mode and press Enter. Once it start in safe mode, try to shutdown. If it able to shut down properly then the problem can be with your antivirus software
Sep 19, 2011 | Dell Vostro 1510 Laptop
Dell vostro 1510 error lights
But the Diagnostic indications says exactly that you needs a Motherboard replacement
Jan 05, 2010 | Dell Vostro 1510 Laptop
The laptop loads up, lets me sign in, then goes blank, no icons
Try booting to the safe mode (F8 at boot) and see if you can log in via the safe mode. If you can't, try booting to your Windows CD, go to recovery console and run CHKDSK /R
If you still can't log in, try running diags see if the hard drive lists a failure.
if no hardware failure found, there and none of those solutions work, then re-installing windows will likely be the final resolution
Oct 06, 2009 | Dell Vostro 1500 Notebook
Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Jun 01, 2009 | Dell Vostro 1510 Laptop
Dell Vostro 1500 Notebook Logo
156 people viewed this question
Alun Cox
